abs light turns on
for a few days now, my abs light and battery light on the dash have been turned on. i did the 15a abs fuse reset under the hood but the abs light is still turn along with the battery lamp. my battery seems fine, i am not quite sure what the problem is because i even did the data link check behind the stereo and there was no code thrown. any help would be appreciated, thanks!
Does it turn on before you start moving or after? You can short that harness with a paperclip. It will beep just the same as the CEL codes do, and it will tell you what the problem is. The wheel sensor could need cleaned...
Did you try doing a search? I remember there being a topic about this before, I think it has something to do with low battery voltage and ur ABS unit not being able to function properly.
yep i did jump the harness and no code was thrown. the abs and battery lamp turns on once i start the car and does not turn off. it stays like that until obviously when i shut my car off, i never had this problem before.
I would also check the output of voltage from your alt. and then check it at your battery. If the voltage differs it could be the power wire coming from the alt. is bad and could cause some electrical issues.
Blaze45
Mar 12, 2013 02:59 PM
RA61825
Sep 30, 2005 03:41 PM
