New mounts but motor still shakes????!?!?!
Old Sep 5, 2006 | 07:20 AM
IVGattaBeDreaming's Avatar
Default New mounts but motor still shakes????!?!?!
I'm really confused. I have a 92 hatch, jdm b16a swap. I changed the drivers side top mount and put a new rear mount on. The car is shaking still when I am cruising at 60. or whenever I get on it pretty hard. all the mounts are good. the other day I noticed that my axle came out an inch or so and it was leaking fluid. so I put it back in and filled the transmission up. Would that mean my axle is out of balance or anything? and that is causing it to shake? or would my car need an alignment really bad or something? I'm trying to think of anything that would make it shake. any help will be greatly appreciated
Old Sep 5, 2006 | 07:23 AM
Heretic:Si's Avatar
Default Re: New mounts but motor still shakes????!?!?! (IVGattaBeDreaming)
lots of things can make a car shake, however your axles shouldn't just come out. i would check them out more thoroughly
Old Sep 5, 2006 | 07:29 AM
Default Re: New mounts but motor still shakes????!?!?! (Heretic:Si)
well that happened to my friend as well and he put them back in and had no problems since. I guess I didn't put them in very good the first time. and they worked themselves out a lil bit, but I dunno... they are brand new Yonaka motorsports axles
Old Sep 5, 2006 | 07:51 AM
1992Si's Avatar
To help seat the axles you may need to hit the end of them with a block of wood and a 3 lb hammer before you put the wheel or spindel back on.
Old Sep 5, 2006 | 08:13 AM
Luserkid's Avatar
Default Re: (1992Si)
Get your wheels balanced.
Old Sep 5, 2006 | 08:32 AM
turbotime's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Get your wheels balanced. </TD></TR></TABLE>
lol hes right! get them aligned too
Old Sep 5, 2006 | 09:02 AM
nsxmatt's Avatar
His axle is coming out of the transmission and people are saying to balance the wheels?
Put the axle in and make sure it seats and doesn't pull out. If the problem is still there find a stock axle, put it in and see if the vibration goes away. Axles reman incorrectly cause vibration problems.
If you want to make sure it's not the wheels just swap them front to rear and see if the vibration has moved but work on the main problem of the axle coming out first, that should throw up a red flag.
Old Sep 5, 2006 | 09:47 AM
Yes I'm pretty sure it's not the wheels but I can get it checked out. I think I need an alignment, but it only does it when I'm on the gas. when I let off the gas in gear or when it's in nuetral it's fine. And if I'm cornering on the gas it's a lot worse.
Old Sep 5, 2006 | 10:13 AM
v4lu3s's Avatar
RTFM
if it is happneing when you are on the gas i am pretty sure it is bad inner joints on your axles.
Old Sep 5, 2006 | 10:52 AM
Default Re: (v4lu3s)
is there a way to tell if you take them out?
Old Sep 5, 2006 | 10:55 AM
fmrprojects's Avatar
Default Re: (IVGattaBeDreaming)
bad alignment, wheels not balanced, bad axles
Old Sep 5, 2006 | 11:42 AM
nsxmatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVGattaBeDreaming &raquo;</TD></TR><TR><TD CLASS="quote">is there a way to tell if you take them out?</TD></TR></TABLE>
You can have them balanced at some machine shops that do axles. Check your local yellow pages.
gettinmoneyny
Jul 2, 2010 08:30 PM
VIS250P
May 28, 2007 08:52 PM
Jesterian
25
Jan 18, 2007 05:24 AM
RenzoDaPlayboi
Jul 11, 2006 03:26 PM
turbob16ef
Nov 12, 2005 01:13 PM
