n/a setup? need opinions
Celebrating 35yrs of Barbie
My goal as far as whp goes, is 190~200 in that range or close to. (id probably settle for 180whp
Anyways im looking to get some high comp pistons, I was thinking USDM or JDM type-r pistons, skunk2 IM, Exhaust manifold/header although im not sure what brand/type to go with, and upgraded valve train(cams, springs, the works...) Oh and the car is a 97 GSR.
Basicly, im unsure of what Exhaust manifold/header, Cams, and what size injectors to go with?
Any opinions or recomendations? and im not really too woried about price, after all you get what you pay for.
And I am fully aware that I will need to get the car properly tuned, which I will do.
Thanks in advance.
)Anyways im looking to get some high comp pistons, I was thinking USDM or JDM type-r pistons, skunk2 IM, Exhaust manifold/header although im not sure what brand/type to go with, and upgraded valve train(cams, springs, the works...) Oh and the car is a 97 GSR.
Thanks in advance.
Well RIght out the box, the STOCK Gsr comes with 176 Hp, So Your close, Get youself some Good headers, Cold are intake, And a cat back exhaust. Go with reputable manufactures. Advance the timing on the distributor a bit and your set.
Also a Good set of all-motor cam shafts will go a big way. All Bolt on and easy for you to do youself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tha_liks »</TD></TR><TR><TD CLASS="quote">Well RIght out the box, the STOCK Gsr comes with 176 Hp, So Your close, Get youself some Good headers, Cold are intake, And a cat back exhaust. Go with reputable manufactures. Advance the timing on the distributor a bit and your set.
out the box it comes with 170 hp...and 140 ish whp...hes nowhere close...and your dreaming if you feel your bolt ons gave you 20-30 hp...
For cams, i would go with some rocket M22x cams. header i would go with a RMF, DTR, SMSP, Rage, or Frofab....to bad all of these headers are 500 +$$$. You could use some DSM injectors or just buy some new RC 310's.
NA power comes at a large price.
greendx
12
Nov 18, 2008 08:05 AM
longislandek123
May 21, 2005 03:29 PM
Bserieskllr
28
Jan 5, 2005 05:09 AM
