ZC swap intake question
Old Sep 4, 2006 | 08:57 PM
BuddhistPriest87's Avatar
Default ZC swap intake question
So I read I can't use the intake manifold from my Si engine on my ZC. If this is true, what should I go get?
Old Sep 4, 2006 | 10:01 PM
crxrocks's Avatar
Get a ZC intake manifold. None of the other D-series IMs will fit (outside of the ~'89 Integra manifold -d16a1)
Old Sep 5, 2006 | 04:35 AM
Autoworks's Avatar
Default Re: (crxrocks)
^^ correct.
You can also send your mani and TB to Maxbore to get bored out...but a different D series SOHC mani will not work on the DOHC ZC
Old Sep 5, 2006 | 05:31 AM
SIred91's Avatar
Rainman
Default Re: ZC swap intake question (BuddhistPriest87)
Yes, but......
You guys are not telling him that as far as parts go, the d16a6 is identical to the SOHC ZC, all parts are interchangeable.............The DOHC ZC is in a ball park all by itself.
Old Sep 6, 2006 | 03:52 AM
Default Re: ZC swap intake question (SIred91)
yeah i didn't get the DOHC ZC, i've got the SOHC...so that means the exhasut will work then?
Old Sep 6, 2006 | 03:53 AM
intake*
Old Sep 6, 2006 | 04:33 AM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhistPriest87 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i didn't get the DOHC ZC, i've got the SOHC...so that means the exhasut will work then?</TD></TR></TABLE>
The exhaust side works regardless of it being a DOHC or SOHC ZC.
Old Sep 6, 2006 | 08:26 AM
Default Re: ZC swap intake question (Autoworks)
yeah i messed that one up...i meant to say intake...but the intake on the sohc will work?
Old Sep 6, 2006 | 09:00 AM
nappyroots827's Avatar
yea it will work, the sohc zc is essentially exactly the same motor as a d16a6, just a little more aggressive cam...but any d16 or d15 sohc intake manifold will swap over...so if you have a few extra bucks layin around i would go with the z6 or y8 manifold, personally i prefer the z6, has longer runners and is a little torqueier (if thats a word)
tyler100
Apr 20, 2008 07:59 PM
Mr.Death
Jun 22, 2006 12:18 PM
justinau
Mar 26, 2004 06:52 AM
Morbspeed
Jan 6, 2004 04:54 AM
VelocityR
Nov 14, 2003 07:22 AM
