Suspension & Brakes Theory, alignment, spring rates....
opinions on itr bar and beaks kit
Old Sep 4, 2006 | 08:38 PM
confucioussae's Avatar
Default opinions on itr bar and beaks kit
i know that just about everyone will recommend the ASR or comptech reinforcement bar, but i want to know if anyone is running a larger sized sway bar (~22mm) with a beaks kit on the EK subframe ? has anyone run into or heard about tearing problems WITH the beaks kit installed ??
Old Sep 5, 2006 | 05:27 PM
broketuner-Sol_Si's Avatar
Default Re: opinions on itr bar and beaks kit (confucioussae)
I ran a beaks kit with a blox 21mm bar, with no problems. Ths was on an EG though, if I were you with an EK I wouldn't bother with a beaks kit, just go ASR. as a derneral rule of thinb for rear swaybar:
For EGs:
19-21mm->Beaks
21+mm->ASR
For EKs:
19mm(or smaller)->Beaks
19+mm->ASR
Just trust me, I've seen tearouts with a beaks kit(using that 22mm bar on an EG coupe)...it wasn't a pretty site, on an EK it'd be even worse ecause the subframe is even thinner.
Old Sep 6, 2006 | 12:59 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: opinions on itr bar and beaks kit (broketuner-sol_si)
I'm using a 23mm ITR bar and a beaks kit... if you have high spring rates, you are less likely to have tearout, as the bar is doing less work.
Old Sep 6, 2006 | 07:34 AM
Default Re: opinions on itr bar and beaks kit (JDM_Ej)
do you have an EK subframe?? thats the one most prone to damage :[
Old Sep 13, 2006 | 03:02 PM
iLOVEthatEMone's Avatar
i have the beaks kit
Old Sep 13, 2006 | 03:03 PM
*** i have the beaks kit for sale i went with the asr myself though
confucioussae
Sep 5, 2006 05:04 AM
CAVTECSol
Suspension & Brakes
May 7, 2006 09:52 PM
1clean00EM1
Suspension & Brakes
10
Oct 16, 2005 07:22 PM
BanEL
May 15, 2003 08:51 PM
halim
May 11, 2002 12:25 AM
