A/C Drain Tube - WHERE? PICS PLEASE (air Condition , Leaks , Water , Passenger)
Old Sep 4, 2006 | 08:35 PM
bzyrice's Avatar
Default A/C Drain Tube - WHERE? PICS PLEASE (air Condition , Leaks , Water , Passenger)
Where is the A/C Drain Tube at? I need a pic please..
My car started to have water in the passenger side after I had my a/c fixed.. seems like it is coming from the a/c .. so I searched and found it could be the a/c drain tube.. need to know where it is..
Thanks!
Old Sep 4, 2006 | 08:44 PM
SOHC4life 96's Avatar
Default Re: A/C Drain Tube - WHERE? PICS PLEASE (bzyrice)
The drain tube is in the engine bay on the passenger side close to the fire wall. It either comes out right next to the inner fender or inside the wheel well. I can't remember exactly. It's a black tube that goes towards the fender then makes a 90 degree turn down to the ground.
Old Sep 5, 2006 | 04:31 PM
bzyrice's Avatar
ok.. anyone that knows exactly where?
Old Sep 5, 2006 | 08:48 PM
bzyrice's Avatar
um i wanna c a pic ..
Old Sep 5, 2006 | 09:14 PM
chrisw85's Avatar
http://www.slhondaparts.com/br...=true
part is detailed under number 15 on that pic. Its against the firewall sorta at the upper end of the footwell on the passanger's side, maybe be hidden by carpet.
Old Sep 6, 2006 | 11:48 AM
bzyrice's Avatar
Default Re: (chrisw85)
thanks!! anyone know of an easy way to clear it out? or check to see if it is blocked?
Old Sep 6, 2006 | 12:27 PM
philosofy1's Avatar
Default Re: A/C Drain Tube - WHERE? PICS PLEASE (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">The drain tube is in the engine bay on the passenger side close to the fire wall. It either comes out right next to the inner fender or inside the wheel well. I can't remember exactly. It's a black tube that goes towards the fender then makes a 90 degree turn down to the ground.</TD></TR></TABLE>
actaully, it goes through the firewall into the engine bay and bends downward, no where near the the fender.
Old Sep 6, 2006 | 12:33 PM
instructor74's Avatar
Default Re: (bzyrice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bzyrice &raquo;</TD></TR><TR><TD CLASS="quote">thanks!! anyone know of an easy way to clear it out? or check to see if it is blocked? </TD></TR></TABLE>
If i remember correctly that tube just slids over a nipple from the ductwork insid the car. You should be able to reach up there and pull the tube off?just work the lip around the fire wall free
Old Sep 6, 2006 | 02:43 PM
bzyrice's Avatar
ok ill try this this weekend?
Old Sep 6, 2006 | 02:47 PM
VisualAutoMotoring's Avatar
Look underneath the glove box, there is this black round thing the evaporator. There is a hose about 8-10" long, you may need to pull back the carpet and the black underlining to see it. The hose runs out to through the firewall, below the battery tray area. It will bend 90 degree's out.
Usually when you are sensing water, its the evaporator core that is "freezing over" and starts to "sweat" out of the evaporator which probably leads to water dripping down kinda like condensation.
Old Sep 7, 2006 | 02:58 PM
bzyrice's Avatar
Default Re: (Hybrid-Performance.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com &raquo;</TD></TR><TR><TD CLASS="quote">
Usually when you are sensing water, its the evaporator core that is "freezing over" and starts to "sweat" out of the evaporator which probably leads to water dripping down kinda like condensation.</TD></TR></TABLE>
yup that is EXACTLY what is happening.. ill feel around under there and ill feel this box that feels like its "sweating" ...
cool so i know i probably just need to unclog the ac drain tube!!
Thanks! Great explanation man!
Old Sep 7, 2006 | 03:05 PM
97civicdx's Avatar
Under the battery, near the front subframe
Old Sep 8, 2006 | 02:16 PM
You may want to open it up also to get rid of the misc. crap its gathered over the years like leaves, branches, dead animals etc. Usually when that happens, it means the evaporator is going bad when its freezing over.
Old Sep 8, 2006 | 11:08 PM
bzyrice's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid-Performance.com &raquo;</TD></TR><TR><TD CLASS="quote">You may want to open it up also to get rid of the misc. crap its gathered over the years like leaves, branches, dead animals etc. Usually when that happens, it means the evaporator is going bad when its freezing over.</TD></TR></TABLE>
how do i do that?
cmc600rr
May 27, 2010 05:29 PM
sohcd16
Mar 15, 2010 01:37 PM
OBDII Integra
Aug 27, 2008 09:11 AM
deviant1
Mar 11, 2004 05:44 PM
fivespeedintegra
Aug 9, 2003 03:41 PM
