LS/VTEC COMPRESSION WITH PR3 PISTONS
i have a b18b1 ls/vtec motor with pr3 pistons arp rod bolts and head studs....i/e/h im running a b16 head with itr intake manifold and throttle body and ctr cams...
im just wondering what my compression is because i checked all the comrpession calculators and they gave me different results
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .cooper. »</TD></TR><TR><TD CLASS="quote">What head? stock valves? was your head milled or your block decked? how many layers are in your headgasket? many factors change compression</TD></TR></TABLE>
yeah everything is stock...i didnt get it milled down or anything.......3 layer headgasket
and i live in cali and i only can get my hands on 91 octane...can i make good power on 91 octane with my compression?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViF CrX »</TD></TR><TR><TD CLASS="quote">bump need info
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">http://www.zealautowerks.com</TD></TR></TABLE>
Everything you need. The reason why this one might be different (or more accurate IMO) is because unlike the c-speed or ff-squad calculators, this one also includes head milling and rod length.
11.94:1 according to the link
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">http://www.zealautowerks.com</TD></TR></TABLE>
11.94:1 according to the link</TD></TR></TABLE>
thanks man for the info but will i make good power on 91 octane with 11.9 cp on a vafc until i switch over to obd-1 and a chipped p28 ecu and hondata?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 »</TD></TR><TR><TD CLASS="quote">if the head/block is not milled and your runing stock valves.
compression with 81mm pr3's with a b16 head should be 11.3 and 11.5 with a gsr head
thanks for the info...is that in the range for a good compression lsvtec motor for daily driving?
thanks for the info...is that in the range for a good compression lsvtec motor for daily driving?</TD></TR></TABLE>
11.5-12.1 is great for daily driving on pump gas
better yet try to find yourslef some p30's
better yet try to find yourslef some p30's</TD></TR></TABLE>yeah i would do that but this block was rebuilt with pr3's in it...ill just leave it in until i have enough money to change them out...
ok i got b18a block decked to like about 8 mills,gsr head shaved to 10 mills ,omni flat valves, block over sized to .20, ctr pistons , s2s3 cams, 70mm tb,pnp head. the only thing that im not sure about is the bearings they are clevete 77. but all the rest its ok.how much compresion and how much power should i be making. by the way its mated to a b16 cable trany with the diff. welded in a 89 crx and a chiped p28. havent gotten tuned yet , just waiting on wilson from puerto rico to tune and harold to degree my cams.any info would be great...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViF CrX »</TD></TR><TR><TD CLASS="quote">im hopein to be keepin up wit srt-4 and cars like that</TD></TR></TABLE>
the only way your goign to krrp up with srt4's is if you go boost or if this motor is droped in some gutted sub 2000 pound tim can crx or civic
the only way your goign to krrp up with srt4's is if you go boost or if this motor is droped in some gutted sub 2000 pound tim can crx or civic </TD></TR></TABLE>
No, my man. No.
Quit shitting on everyone's parade. Simply because YOUR particular all motor setup didn't produce the numbers you wanted, doesn't mean everyone's build will be the same. Go troll around in the Forced Induction forum, where someone might give a ****.
My car weighs 2600+lbs, I run 13.1's trapping 104-105mph.
Gutted, sub-2000lb. CRX? I think not.
SRT-4's are no problem.
- Derek
No, my man. No.
- Derek
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">
No, my man. No.
- Derek</TD></TR></TABLE>
thanks man...yeah i just wanted to know because theres alot of srt-4 owners that think they can smoke every honda out here...i mean i know i cant beat modded srt-4's but i sure can beat a stock one....
No, my man. No.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSERIESPOWER »</TD></TR><TR><TD CLASS="quote">thats true, its your build. i own a 91 da that runs 13.46@97mph all motor, nonvtec and has spanked ls vtecs with nitrous and im sure i'll spank an srt....</TD></TR></TABLE>damn you must have a pretty built motor you got engine specs on that thing
Honda_Noob42385
Feb 26, 2009 04:52 AM
