i have saved up 1k
Old Sep 4, 2006 | 06:54 PM
gsr0103's Avatar
Default i have saved up 1k
wat should i spend it on...
for my stock gs-r 01
Old Sep 4, 2006 | 06:59 PM
atg1290's Avatar
Whatever you want there...Well what are you looing for and we need some pics to see what were dealing with..
Old Sep 4, 2006 | 07:00 PM
gsr0103's Avatar
Default Re: i have saved up 1k (gsr0103)
i mostly drive my car at autox and the twisties....
sorry no pics yet
Old Sep 4, 2006 | 07:08 PM
slow_ls's Avatar
First and most important is suspension. Out of everything don't cheap this. Bigger sway bars also make a huge difference and good bang for the buck. Second since your into auto x and twisties your best bet would be to stay all motor. First intake, because the sound is worth the money alone in my opinion. Get a good header and a free flowing exhaust and go from their. I would also strongly recommend brake and tire upgrades because these will actually make the car much more fun to drive and help alot in auto x times of course.
Old Sep 4, 2006 | 07:09 PM
gsr0103's Avatar
Default Re: (slow_ls)
do u think i should get an aem CAI and a dc sports 4-1 header?
Old Sep 4, 2006 | 07:13 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr0103 &raquo;</TD></TR><TR><TD CLASS="quote">i mostly drive my car at autox and the twisties....
sorry no pics yet</TD></TR></TABLE>
If your autocrossing the car, the first thiong you need to do is decide a class. Then prep it accordingly to the rules for that class.
I run mine in STS, and have Konis, GC springs, a Comptech swaybar, and a CAI.
Old Sep 4, 2006 | 07:18 PM
slow_ls's Avatar
I see you live in cali like me so if smog concerns you I would go with the AEM CAI because of the carb sticker and the dc sports 4-1 is good because of the carb number but I believe the comptech header has a carb sticker as well and is probably higher quality and going to give more power gains. down side is cost but you get what you pay for. But like I said I would do suspension first cause it not only drastically changes performance in all areas but makes the car look kick ***.
Old Sep 4, 2006 | 07:19 PM
gsr0103's Avatar
i think im gonna go with suspension too
but wat can i get with 1k
any suggestions?
Old Sep 4, 2006 | 07:21 PM
slow_ls's Avatar
Go with TunerNoob set up of ground controls and konis. will give you great ride but very firm performance when you turn up the dampening on the shocks. Its a great combo.
Old Sep 4, 2006 | 07:23 PM
gsr0103's Avatar
thanks for the help
Old Sep 4, 2006 | 07:36 PM
Shoobie's Avatar
Default Re: (gsr0103)
Don't forget sticky tires! A good suspension will be almost worthless on bad tires.
Old Sep 4, 2006 | 07:46 PM
Reid's Avatar
Global Moderator
Default Re: i have saved up 1k (TunerN00b)
Spend the money on autocrossing the car in stock class and practicing your driving.
Perhaps also look into tracking your car on a road course to hone your skills further.
Old Sep 4, 2006 | 07:49 PM
Lauj87's Avatar
okay first of all what have you already done to the car? i know you say stock, but some people say stock as in no engine upgrades. for autox you don't want a suspension that is too hard or too soft. i'd suggest a good set of springs, some people like the coil over set but personally i'd go with springs because they are intended for more specific use rather then being fully adjustable and for multipul use. no to mention tuning is alot easier too.
Old Sep 4, 2006 | 07:50 PM
dubs97integ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_ls &raquo;</TD></TR><TR><TD CLASS="quote">Go with TunerNoob set up of ground controls and konis. will give you great ride but very firm performance when you turn up the dampening on the shocks. Its a great combo.</TD></TR></TABLE>
Old Sep 4, 2006 | 07:52 PM
DC2_OTAKU's Avatar
Default Re: (Shoobie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shoobie &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget sticky tires! A good suspension will be almost worthless on bad tires.</TD></TR></TABLE>
werd. good tires, shocks, springs, brake pads, steel braided lines, brake fluid flush/refill, bigger sway bars, rear strut tower bar.
also make sure your motor/gearbox is at least up to OEM snuff before autox'n.....(fluids, spark plugs, filters, belts, etc.)
Old Sep 4, 2006 | 07:55 PM
gsr0103's Avatar
Default Re: (DC2_OTAKU)
my car is literally bone stock
ive only gone to a couple autox events
i usually drive up in the twisties close by
Old Sep 4, 2006 | 08:16 PM
three stars, two bars's Avatar
From: knee deep among your wreckage and uncertainty
strippers and beer
Old Sep 4, 2006 | 08:18 PM
gsr0103's Avatar
Default Re: (three stars, two bars)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by three stars, two bars &raquo;</TD></TR><TR><TD CLASS="quote">strippers and beer </TD></TR></TABLE>
haha nice one
Old Sep 4, 2006 | 08:50 PM
Seriously though, depending on your mileage, you might want to get a good 21 point inspection, and get some routine maintenance taken care of while you've got the extra dough.
Old Sep 4, 2006 | 09:29 PM
DA9ReMiX's Avatar
Full Coilover Kit w/ bigger sway bar!
Old Sep 4, 2006 | 09:49 PM
Fat Chick Magnet's Avatar
koni yellow sport shocks w/ground controls and itr rear sway bar. OVERRRSTEERRRRRRR
Old Sep 4, 2006 | 09:51 PM
DC5StylZ's Avatar
seriously
Old Sep 4, 2006 | 10:58 PM
Default Re: (hondacuraLs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondacuraLs &raquo;</TD></TR><TR><TD CLASS="quote">seriously </TD></TR></TABLE>
I'm glad someone shares my enthusiasm.
Old Sep 5, 2006 | 01:31 AM
AdeJong 03's Avatar
do suspension
i recommend some koni yellows and performance springs. depending on the drop you want.
id get springs, shocks, and a comptech tie bar and rear sway
bolt ons wont do nearly as much as suspension upgrades in your case
Old Sep 5, 2006 | 02:35 AM
atg1290's Avatar
You should have left over cash from suspension if you deceide to go with that...
