b18b VS. b18a
Old Sep 4, 2006 | 03:58 PM
latinf86's Avatar
Default b18b VS. b18a
can someone please tell me the difference between the 2, just the block. cause i baught a b18a block for my lsvtec and i wanna know if i made a big mistake
Old Sep 4, 2006 | 04:02 PM
E_F_9's Avatar
most lsvtec i have seen use a1 blocks.I do not think there is big difference if any.
Old Sep 4, 2006 | 04:07 PM
88sleeperx's Avatar
Default Re: (E_F_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E_F_9 &raquo;</TD></TR><TR><TD CLASS="quote">most lsvtec i have seen use a1 blocks.I do not think there is big difference if any.</TD></TR></TABLE>
x2
Old Sep 4, 2006 | 04:29 PM
IntegraGuy16's Avatar
Default Re: (88sleeperx)
they are the same thing, a1 was 1993 and below and the b18b1 was 94+
Old Sep 4, 2006 | 05:30 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (IntegraGuy16)
Same engine, slight increase in power due to better intake manifold and cams
Old Sep 4, 2006 | 05:33 PM
f-it3's Avatar
Default Re: (Deetz)
i believe one of them you have to tap a hole for the knock sensor...don't quote me on that one.
Old Sep 4, 2006 | 06:13 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (f-it3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f-it3 &raquo;</TD></TR><TR><TD CLASS="quote">i believe one of them you have to tap a hole for the knock sensor...don't quote me on that one.</TD></TR></TABLE>
Both block are non vtec without a knock sensor, they are the same block and head
Old Sep 4, 2006 | 06:16 PM
civhatch90's Avatar
i dont know about physical differences but a1's usually have higher milleage
Old Sep 4, 2006 | 06:19 PM
digitally_remastered's Avatar
Default Re: (civhatch90)
very easy to get a hold of. got my b18a1 block for free, so im building a turbo ls motor.
Old Sep 4, 2006 | 07:11 PM
Targa250R's Avatar
be professional
Default Re: b18b VS. b18a (latinf86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by latinf86 &raquo;</TD></TR><TR><TD CLASS="quote">can someone please tell me the difference between the 2, just the block. cause i baught a b18a block for my lsvtec and i wanna know if i made a big mistake </TD></TR></TABLE>
Not a mistake at all, especially since you won't be using the cylinder head. The B18A1 will be fine.
- '90-91 B18A1: pre-OBD, 130hp, 121 lb-ft
- '92-93 B18A1: OBD-1, 140hp, 126 lb-ft
- '94-95 B18B1: OBD-1, 142hp, 127 lb-ft
- '96-01 B18B1: OBD-2, 140hp, 124 lb-ft
Old Sep 4, 2006 | 08:02 PM
bag's Avatar
bag
Default Re: b18b VS. b18a (Targa250R)
most use a1 cause you can get them dirt cheap and they rebuild them anyway so you dont care about the condition...with the b18b you're talking usually around $500+ for good running motor,,for a1 you're talking around $50-$100 usually..but at some pick and pulls they just charge $100 for any 4 banger,,even if you can find a b16 or gsr
turboteg90
Feb 18, 2008 09:06 PM
t . b o z
May 27, 2004 05:26 PM
BLUE EH3
Oct 29, 2003 09:51 PM
Sketch_hs
10
Sep 29, 2003 06:02 PM
Big Dick Bandit
Sep 9, 2003 10:41 PM
