Dash Electrical Problem - Need Help!
Old Sep 4, 2006 | 01:50 PM
yoguy's Avatar
Default Dash Electrical Problem - Need Help!
New member, who has done a search, needs help!
I'd like to disable/disconnect the factory alarm (under-dash location?) that signals when door and/or seat belt circuits are open.
My 90 DX hatch has a dash warning light that remains "ON" indicating a door is open. The light is on when both doors are closed and the alarm starts beeping a few moments after getting under way - it won't go off! I want if fixed or "OFF" with no complications.
I've removed and cleaned both door switches, with no change. I have not yet tested the switches for proper function.
Before diving into a myriad of electrical woes, will anyone offer some likely causes and solutions?
Thanks, in advance!
Old Sep 4, 2006 | 04:11 PM
yoguy's Avatar
Default Re: Dash Electrical Problem - Need Help! (yoguy)
Bump - Just looking for some help!
Old Sep 4, 2006 | 05:01 PM
hates hondatech's Avatar
* B A N N E D *
buy new switches instead of riggin ****.
Old Sep 4, 2006 | 05:43 PM
EF Boy1231's Avatar
i would deffinitly say switches. not the beepin noise under the dash.
Old Sep 7, 2006 | 06:21 AM
yoguy's Avatar
Default Re: Dash Electrical Problem - Need Help! (EF honda EF)
It's not the door switches - I swapped the switches from my Prelude to the Civic; they are the same. The "door open" dash light still stays on after the swap.
Anybody have similar problems with their alarm/sensor where it won't stop beeping?
Are the seat-belt switches a possible problem?
And I'd still rather disable the alarm permanently.
Thanks for all advice!
Old Sep 7, 2006 | 07:08 AM
rbwdriven's Avatar
I had the same issue with the overhead light/dash light always being on. I bought new switches and it went away. I tried using my switches off of my crx and it did not fix it so I bought new ones just to try and it fixed it.
shakeandbakerab
Oct 28, 2018 03:09 PM
Kevp
Audio / Security / Video
Apr 9, 2014 07:29 AM
awdracer6
10
Jan 25, 2012 08:14 PM
