1988 Honda Accord Idle
Old Sep 4, 2006 | 01:43 PM
123216's Avatar
Default 1988 Honda Accord Idle
1988 Honda Accord, carbureted, 287K miles, recently when engine warms up, sitting at idle, engine races up to approx. 2500rpm and down to 300 rpm ( almost stalling) back and forth. Only way to get engine to idle normally is to plug air suction port in air cleaner.
Old Sep 4, 2006 | 01:55 PM
Ross 2.0's Avatar
In a Junkyard near you.
sounds like you already solved the vaccum leak then. So if you plug the air intake it quits?
Definately sounds like a vaccum leak
Old Sep 4, 2006 | 09:18 PM
123216's Avatar
Default Re: (MooGoCow3)
ok..so it is a vacuum leak??..however...I should not have the air suction port in air cleaner plugged. What is the most likely cause?? or area to check for a vacuum leak??
JerryCT
Aug 13, 2017 07:03 AM
bdmlilburn
Oct 21, 2013 06:53 AM
KristjanL
Dec 29, 2011 05:07 PM
Rat Rod
Feb 9, 2011 08:20 AM
olds_442
Jul 13, 2003 08:54 PM
