turbo xs quad stage
Old Sep 4, 2006 | 01:36 PM
CRXMEX901's Avatar
Default turbo xs quad stage
what is the best way to set the quad stage boost controller?i have a gsr 700hp+ hondata S2000
Modified by CRXMEX901 at 2:48 PM 9/4/2006
Modified by CRXMEX901 at 2:56 PM 9/4/2006
Old Sep 4, 2006 | 01:37 PM
vtekthis's Avatar
Default Re: turbo xs quad stage (CRXMEX901)
what kind of engine mang? this will help us to let you know
Old Sep 4, 2006 | 01:41 PM
vaporboy12's Avatar
Default Re: turbo xs quad stage (vtekthis)
yeah as darren said what engine mangament?
Old Sep 4, 2006 | 04:10 PM
Turbocivic94's Avatar
quad stage wont work with S200
Old Sep 4, 2006 | 05:28 PM
darkdayz's Avatar
Default Re: turbo xs quad stage (Turbocivic94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocivic94 &raquo;</TD></TR><TR><TD CLASS="quote">quad stage wont work with S200</TD></TR></TABLE>
Are you positive?
Old Sep 4, 2006 | 07:58 PM
SFWD 1934's Avatar
Default Re: turbo xs quad stage (darkdayz)
Well it techincally work with any EMS. What Turbocivic94 is letting you know that all 3 of the electronic boost solenoids can be activated through S200. There is only 2 output controls on the S200. There is always ways to make things work together.
Jason
Old Sep 5, 2006 | 06:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkdayz &raquo;</TD></TR><TR><TD CLASS="quote">
Are you positive?</TD></TR></TABLE>
You can use nitrous control on S200 but it doesnt have enough outputs.
Old Sep 5, 2006 | 12:03 PM
NJcoupe's Avatar
It all depends on the ECU. A p72 will have more outputs then a P28 and so on.
Most likely you aren't making 700hp on a stock IM so if you have a p72 you can use the IAB solenoid as an output also.
Old Sep 5, 2006 | 04:39 PM
XXXRacing's Avatar
Default Re: turbo xs quad stage (dxcoupe.)
You can control without an EMS
Old Sep 5, 2006 | 05:36 PM
Default Re: turbo xs quad stage (XXXRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XXXRacing &raquo;</TD></TR><TR><TD CLASS="quote">You can control without an EMS </TD></TR></TABLE>
old skool 3 switches
Old Sep 5, 2006 | 08:36 PM
SFWD 1934's Avatar
That's what I am saying!
Jason
Old Sep 5, 2006 | 08:42 PM
Arturbo's Avatar
Better than steak
25 Year Member
msd
Old Sep 6, 2006 | 03:09 PM
red cx's Avatar
Default Re: turbo xs quad stage (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">
msd</TD></TR></TABLE>
msd??
Old Sep 6, 2006 | 03:23 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: turbo xs quad stage (blue89crx)
yes
Old Sep 6, 2006 | 03:27 PM
vaporboy12's Avatar
a progressive nitros controller should do the trick too
Old Sep 6, 2006 | 04:28 PM
PPLH8R's Avatar
I think that Arturbo is talking about the new MSD time delay switch box ? But I thought that the unit only had 2 outputs or am I wrong ?
http://msdignition.com/2006/06-17.htm
Old Sep 6, 2006 | 05:34 PM
CRXMEX901's Avatar
Default Re: turbo xs quad stage (PPLH8R)
HOW BOUT SOME MICRO SWITCH OR SHIFT LIGHT? THEY CAN ACTIVATE IT ALSO? THE MSD IS TIMED WILL BE VERY ACCURATE DO TO RUNS BEING DIFFRENT EACH TIME
Old Sep 6, 2006 | 09:17 PM
SFWD 1934's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PPLH8R &raquo;</TD></TR><TR><TD CLASS="quote">
http://msdignition.com/2006/06-17.htm</TD></TR></TABLE>
Wrong one.
Jason
Old Sep 7, 2006 | 09:44 AM
PPLH8R's Avatar
Is there another unit that Iam not seeing or are we talking about something else all together ?
Old Sep 7, 2006 | 02:54 PM
dome's Avatar
Default Re: (PPLH8R)
i looked into the msd before. when its all said and done buying the quad stage and the msd unit. its around 800 bucks i think. i got a question for brian or jason. im using the fast ems and i have 4 nos outputs on it can i use them. the only thing is they are rpm triggered. does it have a delay. pm me how did you guys do it using the fast ems. thanks
Old Sep 7, 2006 | 09:00 PM
1FSTHATCH's Avatar
Default Re: (dome)
I thought you can set them ports to recognize gear activation or shift points??
Old Sep 7, 2006 | 09:08 PM
SFWD 1934's Avatar
Default Re: (dome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dome &raquo;</TD></TR><TR><TD CLASS="quote">i looked into the msd before. when its all said and done buying the quad stage and the msd unit. its around 800 bucks i think. i got a question for brian or jason. im using the fast ems and i have 4 nos outputs on it can i use them. the only thing is they are rpm triggered. does it have a delay. pm me how did you guys do it using the fast ems. thanks</TD></TR></TABLE>
Yea you are right, it can add up to as much as an EMS. I choose this way becasue I wanted it to run differently. Now you can also look into the Dedenbear or Biondo products as well.
Jason
Old Sep 7, 2006 | 09:59 PM
ninesecrx's Avatar
Default Re: (SFWD 1934)
You use the MSD box that controls automatic transmission shifts
Old Sep 7, 2006 | 10:24 PM
SFWD 1934's Avatar
I ran across this one as well. I have never used thier products before except the injector drivers. Pretty reasonable prices as well:
http://www.fjoracing.com/produ...oller/
That one has two outputs. But if you use one in the EMS, there you go.
Jason
Old Sep 8, 2006 | 03:02 AM
dome's Avatar
Default Re: turbo xs quad stage (SFWD 1934)
if its going to cost around 800 bucks why not just go with the nrl or innovitive one. here is to msd boxes you could use http://www.msdignition.com/tc_10.htm orhttp://www.msdignition.com/tc_9.htm .
