Suspension & Brakes Theory, alignment, spring rates....
suspension mods for a rex?
Old Sep 4, 2006 | 11:56 AM
Subterraneous's Avatar
Default suspension mods for a rex?
Tien Springs 7/6
Rear Disc Brake Conversion
EF EX 10.3” brakes and knuckles (front)
Koni Yellow Shocks
Polyurethane radius arm bushings
Heim Joints for sway bar
i havent decided what kind of wheels i want, im debating 14" v. 15"
i was thinking of throwing on some Si wheels (the 7 spoke ones) but then i thought about going 14", and the 14" honda wheels are pretty skinny arent they? i wanna run at least 195-205 tires. what decently light 14x6.5/7 wheels are there?
Old Sep 4, 2006 | 01:55 PM
Default Re: suspension mods for a rex? (Subterraneous)
and im also gonna try to run DA UCA's front and rear
Old Sep 6, 2006 | 08:11 PM
bumpidy bump
Old Sep 6, 2006 | 08:58 PM
ED9man's Avatar
Why the hell would you run DA UCAs?
Old Sep 7, 2006 | 02:20 PM
Default Re: (ED9man)
cheap fix for negative camber in the front. the DA UCA's are about 1/16th of an inch longer than the stock EF UCA's.
any more comments? especially about wheel choices?
Old Sep 7, 2006 | 03:04 PM
TunerN00b's Avatar
Default Re: (Subterraneous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Subterraneous &raquo;</TD></TR><TR><TD CLASS="quote">cheap fix for negative camber in the front. the DA UCA's are about 1/16th of an inch longer than the stock EF UCA's.
any more comments? especially about wheel choices?</TD></TR></TABLE>
So, less static camber and a weaker camber curve due to the longer UCA in comparison to the stock length LCA. Sounds like an overall lose-lose situation to me.
Why do all these suspenion mods if you aren't going to corner the car hard? And if you are going to, then you'll want that camber.
Old Sep 7, 2006 | 09:55 PM
Default Re: (TunerN00b)
its a honda not a race car. less static camber = less tire wear. if you can find me a chart that compares the camber curve of a stock ef suspension setup, and one with a UCA thats 1/16th of an inch longer and there is a big difference, then ill probably scrap that idea. until then, i dont mind losing that extra .01g on the skidpad, or .2 mph in a 700 ft. slalom.
ill say it again. its a daily driven honda, not a race car.
90JDMEF8
Jun 28, 2009 01:35 AM
96accordsir
Nov 21, 2008 09:06 PM
russianswty
Jan 25, 2007 02:38 PM
A016
Suspension & Brakes
Jun 29, 2005 11:35 AM
Black R
28
Jan 10, 2005 07:38 PM
