99 Accord EX Gearbox night illumination problem
Hello,
I have a 99 Accord EX and the gearbox does not illuminate at night. Also there is no illumination on the master controls on the driver door. Should there be? I am pretty sure the gearbox should though. If it is a bulb issue how do you change it?
can you shed some light as to what your really talking about with the gearbox? Surely you don't expect the transmission to light up. The shifter possibly? I don't recall if that lights up or not.
I have a friend who had his center console shift illumination light go out on his Toyota. He said that he had to replace the bulb located beneath the center console shifter.
Because it seems like only the driver door and gearbox lights are affected, it's probably nothing more than needing to replace the bulbs.
tolly
Mar 25, 2008 05:42 AM
