Removing/Reinstalling Air Conditioning...
Old Sep 3, 2006 | 02:24 PM
skytanker2003's Avatar
Default Removing/Reinstalling Air Conditioning...
Hey everyone,
I have a question that I haven't been able to get a solid answer to....
I have a '96 Civic HX and a '96 CX. The HX has all the goodies like P/S, P/W, P/L, and A/C. The CX is the base model with no added power accessories. But the CX is lighter and better for a turbo kit and I am planning on selling the HX anyway. Well...I want to put the Air Conditioning from the HX into the CX. Has anyone here done it, have any input on how it can be done, or know of a DIY anywhere? Thanks for whatever help you can give me!!!
Old Sep 3, 2006 | 03:58 PM
TeamNextGenChris's Avatar
Default Re: Removing/Reinstalling Air Conditioning... (skytanker2003)
i did it in my daily driver CX...i made a parts list-let me find it and i'll post it up.
can't find the post..anyway.
you'll need to remove all the parts in the engine bay.that includes:
compressor
condenser
fan
all hard and soft lines up to the firewall,and everything connected to them
wiring harness that goes fom the compressor area over to plug in behind the passenger headlight
inside the car:
the evaporator box
A/C switch from the dash.
some pics to clarify:
the evaporator box is what's located under the dash.it's parts #4 and 5.
part #23 is the harness that goes behind the radiator,over to the compressor.
these are all the hoses and pipes you'll need to remove.also pictured are the condensor,evaporator box,drier and compressor.
the entire setup,assembled.
plug the harness in on the new car(the plug is there,just nothing going to it).
put all the components into the engine bay.
install the switch into the dash
install the evaporator box into between the heater core and fanbox.it will replace the empty box that's currently there-put that in the old car to take the place of what you removed.
there may be a relay that needs to be swapped over too-it's been so long i can't remember.compare the underhood fuse boxes on both cars and see if there's anything A/C related.
replace the dyer and expansion valve whiel it's all apart.also replace all o-rings.
recharge the system and you're done.
this is just a quick rundown.if i missed anything or you have any questions,let me know.
Chris
Modified by TeamNextGenChris at 1:24 AM 9/4/2006
Old Sep 3, 2006 | 04:32 PM
RockLee`'s Avatar
Default Re: Removing/Reinstalling Air Conditioning... (TeamNextGenChris)
wonderful reply nextgen.
sticky this in the FAQ
Old Sep 3, 2006 | 04:34 PM
Default Re: Removing/Reinstalling Air Conditioning... (RockLee`)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RockLee` &raquo;</TD></TR><TR><TD CLASS="quote">wonderful reply nextgen.
sticky this in the FAQ</TD></TR></TABLE>
if it's gonna be stickied,i'll go back thru it and give more details and pics
really sucks that i can't find my old how-to on it.it was about five times longer than my above post,had part numbers,tons of pics,etc....i put a lot of time into it
chris
Old Sep 12, 2006 | 06:51 AM
Hey, thanks for the quick and detailed info! If you can find me the legend so I know what some of those numbers are, that would be great...but if not, that's okay! It looks like it's prolly out of the Honda dealership's big book of parts! Anyway...Thanks again!!!
Old Sep 12, 2006 | 07:54 AM
DeucesWild's Avatar
sounds like nextgen knows wtf is up on this shizzy...... just remember to have your lines vacuumed out BEFORE you recharge the system (you should be able to find any a/c shop/tech to do this for you, and requires a machine to do so). then leave the vacuum in the lines for when you charge it
just my $0.02
Old Sep 12, 2006 | 10:31 AM
t0p_sh0tta's Avatar
Default Re: (DeucesWild)
They leave the system in a vaccum to ensure that there are no leaks.
Old Sep 12, 2006 | 12:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeucesWild &raquo;</TD></TR><TR><TD CLASS="quote">sounds like nextgen knows wtf is up on this shizzy...... just remember to have your lines vacuumed out BEFORE you recharge the system (you should be able to find any a/c shop/tech to do this for you, and requires a machine to do so). then leave the vacuum in the lines for when you charge it
just my $0.02</TD></TR></TABLE>
that's definitely the route to take.
i'm a cheapass though,and just assembled everything(remember to use new O-rings,and clean and dry all the lines thoroughly)and recharged the system.no problems doing it that way.
CHris
Old Sep 13, 2006 | 10:41 AM
DeucesWild's Avatar
Just in case you have any other questions....
https://honda-tech.com/zerothread/1665946
*****before clicking link: order a pizza, p/u a 6-pack, and grab a pen and paper......... cuz you are gonna be there for a while*****
nihad
Feb 24, 2012 11:23 PM
ek coupe
May 22, 2009 10:35 PM
Sp00nFed EM1
Sep 13, 2007 05:54 AM
HiProfile
Nov 3, 2006 09:08 AM
