Drag CRX's what size slicks/wheels are you using?
Old Sep 3, 2006 | 12:01 PM
djnikko's Avatar
Default Drag CRX's what size slicks/wheels are you using?
As the title says, Im looking to buy some slicks and wheels just wanted to get an idea of what everyone was running. Please could you also state your HP
Thanks in advance
Old Sep 4, 2006 | 01:54 PM
CRXMEX901's Avatar
Default Re: Drag CRX's what size slicks/wheels are you using? (djnikko)
I HAVE 700 HP CRX I AM RUNNING M&H SLICK 24.50X9X13 ON LENSO I RAN A 10.4@149 I AM CHANGING TO MICKY THOMPSON ON WELDS MAGNUMS I HEARD THEY GRAB BETTER
Old Sep 4, 2006 | 02:25 PM
Garage 808 Hatch's Avatar
im running M&H 25x8.7.13 on lenso 13x7. ran 10.4 @ 137mph, 463 whp, 1.65 60fts
Old Sep 4, 2006 | 03:42 PM
djnikko's Avatar
Default Re: (Garage 808 Hatch)
Thanks for the replys Where can I get some 13 x 7 wheels (lenso or not)?
Are the 2 tyre sizes mentioned above a pretty common size?
Old Sep 4, 2006 | 08:46 PM
ya, mine are available all day from m&h. diamond racing makes inexpensive 13x7's, lenso, bogart, weld, etc for wheels
Old Sep 5, 2006 | 01:27 AM
djnikko's Avatar
http://www.diamondracingwheels.com/WheelSeries.htm
Thanks
Old Sep 5, 2006 | 03:46 AM
djnikko's Avatar
Default Re: (djnikko)
Im looking for a budget setup basically, not worried about how the wheels look. I know I can use stock 14inch alloys/steelies but am worries about slick sizes. What size/brand slick do people run on their stock 14's?
Old Sep 5, 2006 | 09:59 AM
raene's Avatar
Too hard to find wide enough stock wheels to run 8"+ slicks. Better to run wider wheels, most stockers are 6.5" IIRC. And 14" slicks are hard to come by, I looked already.
Old Sep 5, 2006 | 10:50 AM
djnikko's Avatar
Default Re: (raene)
I have 3 options basically... (ranging from cheapest to most expensive)
Option 1. Go with my 14" stock CRX alloy wheels but maybe pay more later down the line for replacement slicks.
Option 2. Go with some 13 x 6j wheels I have seen cheap online, but the same issue may apply with the slicks as above.
Option 3. Buy some Diamond racing or Lenso 13 x 7 wheels and get the wider range or slicks (quite literally...)
My personal favourite is option 2, are slicks for 13 x 6j wheels easy to come buy?
As I said im really not bothered about fashion more so function. I will not be doing anythign to the rear of the car wheel or tyre wise (other than having either stock wheels with normal road tyres or my 16" alloys with slightly better performance street tyres) I notice some people put the skinny tyres on the back but I dont think im quite in that league yet
Old Sep 5, 2006 | 10:52 AM
djnikko's Avatar
I also see alot of stock honda 15inch alloys appearing on ebay, it would not be out of the question to get a set of these as it appears alot of slicks come in a 15" diameter but I could be wrong.
Old Sep 5, 2006 | 04:20 PM
raene's Avatar
As I said it's not the diameter it's the width. You need a 7" minimum, a lot of the larger slicks must be mounted on a 7" minimum. Look at the pricing Exospeed has on the Lensos, they're not THAT expensive. I got their Lenso/M&H combo.
Old Sep 5, 2006 | 06:03 PM
Machine1's Avatar
We are using 24.5x8.5x15 M&H Slicks on 99-00 Si 15" wheels on an 89 Hatch.
You have to run extended wheel studs, wheel spacers, and crank the coilovers up very high to run that wheel/tire combo.
Old Sep 5, 2006 | 07:34 PM
speeddave's Avatar
Default Re: Drag CRX's what size slicks/wheels are you using? (Machine1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Machine1 &raquo;</TD></TR><TR><TD CLASS="quote">We are using 24.5x8.5x15 M&H Slicks on 99-00 Si 15" wheels on an 89 Hatch.
any pics of the setup?
Old Sep 5, 2006 | 08:01 PM
red cx's Avatar
Default Re: Drag CRX's what size slicks/wheels are you using? (speeddave)
Im in the process of building a crx now and plan on running some 33's!! JK
Old Sep 6, 2006 | 07:30 AM
Machine1's Avatar
Those were the only two pictures I could find.
Old Sep 6, 2006 | 12:10 PM
d16dcoe45's Avatar
Why go with stock size wheels? They are very limited in width, plus with an 8 or 9" slick you will have to run spacers because of the stock (45mm) offset--the slicks will rub. You can get a 13 x 7 or 13 x 8 Diamond Racing wheel in silver or black, 13 lbs. around $50 each. It makes the most sense. Unless you want to spend a little more for the Lensos but the Diamonds are so cheap its hard to resist. If I hadn't gotten Lensos a few years back (I didn't know about Diamonds then), I would have went with Diamonds.
Old Apr 3, 2007 | 07:22 PM
djnikko's Avatar
Default Re: Drag CRX's what size slicks/wheels are you using? (d16dcoe45)
Do you know of any diamond racing wheel stockists? Im having a hard time finding a place that will ship oversea's to the UK.
The good news is Ive found some slicks in the UK. I was told to go with 8 x 15 or 8 x 13 wheels by a guy from hoosier uk but I have a feeling the 15's would give me grief on the arches.
Cheers
Old Apr 3, 2007 | 11:14 PM
88ED8's Avatar
Lets say I had a crx and wanted to run 13x8" rims ( http://www.diamondracingwheels...s.htm ) with M&H 13x8x23 slicks, how much of a backspace would I need???
Old Apr 4, 2007 | 07:57 AM
regamaster's Avatar
We are using 26x8.5x 15 / with Weld wheels. just getting the chassis dialed in and getting 1.54 60fts.
Old Apr 4, 2007 | 10:03 AM
djnikko's Avatar
Default Re: Drag CRX's what size slicks/wheels are you using? (regamaster)
did you have any arch fitment issues running the 15's on a CRX?
What kind of offset should I be looking at also?
Any help is appreciated
Thanks
Old Apr 4, 2007 | 01:58 PM
regamaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote">did you have any arch fitment issues running the 15's on a CRX?
with the 26" slick and a 15" wheel you will have some clearance issues. We had to cut some of the body to make it fit. We are using a 5.5 back spacing and using a 1/4" spacer.
Old Apr 4, 2007 | 10:45 PM
88ED8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Lets say I had a crx and wanted to run 13x8" rims ( http://www.diamondracingwheels...s.htm ) with M&H 13x8x23 slicks, how much of a backspace would I need??? </TD></TR></TABLE>
Anybody????
miab18c1
Wheels
Mar 15, 2011 08:38 AM
85
Aug 7, 2006 07:30 PM
revolt_allmotor
Dec 31, 2005 02:37 PM
not so civic
Jun 15, 2002 08:52 AM
Kamin
Mar 4, 2002 12:04 PM
