prblems with speaker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugbeme »</TD></TR><TR><TD CLASS="quote">i have a 99 accord. does anyone know what could be wrong if none of my speakers are not working. is it a fuse issue? if so where is the fuse located??</TD></TR></TABLE>
[sarcasm]None of your speakers are not working, which means that all of your speakers work. Fuse issue? If your speakers are working, then no. The fuse is located in the fuse box.[/sarcasm]
You need to be more specific. Does your head unit turn on? If not, then yes, it could be a fuse issue. If it does turn on, then either blown speakers (unlikely), faulty head unit, or a wiring problem (unlikely).
It's not a fuse issue, because your radio works. As I said before, be more specific. Is it a stock radio or aftermarket? What happened when the speakers stopped working? Did they go out one by one? All at once? Maybe you were messing with the wiring and shorted something out, and then they stopped working? What's the story here?
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Go thru and make sure none of the speakers are grounding out. Are they factory speakers? Then go thru and check the wiring off of the aftermarket head unit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugbeme »</TD></TR><TR><TD CLASS="quote">what do u mean grounding out??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater »</TD></TR><TR><TD CLASS="quote">speakers leads touching....each other.</TD></TR></TABLE>
That would be shorting out, since both sides are driven.
Close enough.
Maybe the head unit has a separate plug for speaker outputs and that came out. Seems unlikely though.
Factory speakers or aftermarket, and is the speaker wiring stock or upgraded?
Close enough.Maybe the head unit has a separate plug for speaker outputs and that came out. Seems unlikely though.
jamvisuals1
Audio / Security / Video
Oct 11, 2015 07:54 PM
Steven P
Jun 27, 2015 03:11 PM
Mishima
Jun 30, 2009 09:08 PM
