HELP: How to remove factory radio?
Old Sep 3, 2006 | 09:34 AM
accord06's Avatar
Default HELP: How to remove factory radio?
Hey, I have a 2006 Accord Non-Nav, Auto Transmission. I was wondering if anyone had a pdf or a link showing how I can remove the factory radio?
Old Sep 3, 2006 | 01:17 PM
Ross 2.0's Avatar
In a Junkyard near you.
Get a hook shaped tool and pull on the outer edges of the center vents to release the hooks then pull up. remove the screws.
pop off the shifter trip (unhook one seat heater connector (if equipped)
Pop out the cointray insert and remove the two screws. Pop that out and let it hang off at the passenger side by the wires.
remove the two screws from the compartment and with the door closed pull it out by grabbing the top and bottom of the door. Look under the radio and remove the two 8mm bolts securing it to the dash.
Pull like hell to get it out and be careful not to break the clips.
yomayo
Nov 22, 2006 05:11 PM
Protoss
Mar 9, 2006 04:42 PM
giff74
Mar 19, 2005 02:09 AM
TMNcivic
Audio / Security / Video
Mar 5, 2005 02:15 PM
. o 69 o .
Apr 15, 2003 08:36 PM
