Bushings: poly vs. hard rubber vs. spherical
Old Sep 3, 2006 | 09:31 AM
white rocket's Avatar
Default Bushings: poly vs. hard rubber vs. spherical
I have been reading numerous threads for the past week regarding suspension bushings. Mostly upper/lower front/rear control arms. I plan to do a complete upgrade over the fall/winter. Based on my readings it seems that the poly urethane debate is neverending. Some like 'em and some don't.
One thing that has confusd me a bit is the use of spherical bearings. I'm no guru so this baffles me a bit. Using a rubber bushing(OEM/Mugen) will allow minimal movement in that area. Using a ploy bushing will restrict that movement even more, perhaps even bind under load. Some seem to favor this result and some don't. Then, the spherical bearing seems to allow almost a free range of movement, which to me, seems counter productive.
Someone care to explain?
To give everyone an idea as to where I am at I'll provide a list of what I have ordered and what I'm still deciding on.
<U>What I got so far(uninstalled)</U>
Mugen engine mount set
Spoon N1 12Kf/14Kr
Mugen front compliance set
Mugen rear trailing arm set
<U>What I'm looking at still</U>
This kit: http://www.orijinmotorsports.com/proddc2ren.html
King Motorsports spherical rear upper arm
The formula link kit found here: http://www.technicasport.co.jp/eng/kit.htm, scroll down to second pic. These seem to be next to impossible to get in North America.
A-Sports front and rear upper control arms
Using the Orijin upper and lower arm kit with the Skunk2 adj. FUCA and the Omni or stock FLCA
Again, I'm not sure where the spherical bearings would help and in what area of the suspension. Just the lower control arms, upper and lower, front and back?
Suggestions, comments and opinions welcome
Old Sep 3, 2006 | 04:11 PM
8400rpm's Avatar
your going with Spoon N1 suspension??
there an awesome set of suspension
Mugen_DC2R
Sep 28, 2006 02:25 PM
rmcdaniels
29
Apr 12, 2006 06:00 PM
drumminforev
24
Apr 12, 2006 12:53 PM
civais
Jan 19, 2005 02:01 PM
