what size tires for 15x7.5 wheels?
got some new 15x7.5 wheels on my EF and i was wonderin whats the best size tire to fit? i was just thinkin 205x50 but i wasnt sure. any help would be saaaweeeet.
go 215 50 widder but more expensive remember the lower profile and the wider you go the more expensive you go 215 60 it will fill the wheel well up better..is you car lowered are they steelies or rims?
for a honda i would just got 205-50's, for my corolla's i would stretch some 195's, and thats not a stretch either. worry more about the tire itself, not the size. what wheels and what offset?
Marcus
Marcus
get a pair of used 205-50's mounted on and test drive them on the front and then on the back, if either rubs then buy 195-50's and roll your ****.
Marcus
Marcus
dont get 195s damn bicycle tire get 215 50's unless you car is slammed they wont rub especially some drag wheels 195 is not wide engough how do you go to the track with 195's. the width is not what you have to whatch out for it is the heighth of the tire ie 50 go with the 215 you will not spin as hard as you would with the 195 ignore the other advice
uh width does matter with rubbing, but i guess not so much in the honda world no one gets a good enough offset to rub on the sides, thats why i said put on a 205 if they rub go smaller. and i think almost all corollas go to the track on 195's basically, we try and break traction in the rear, gotta remember that.
Marcus
Marcus
BLOODIAMOND72
Dec 29, 2010 10:20 AM
Noir
11
Sep 27, 2006 10:02 AM
