Best psi to run to guarontee longivity h22a
Old Sep 3, 2006 | 02:07 AM
whophlungpoo's Avatar
Default Best psi to run to guarontee longivity h22a
Okay, before I go further, here's my setup:
General Vehicle Information:
Year: 1996/1992
Make: Honda
Model: Prelude
Trim: VTEC
Bodystyle: Coupe (2Door)
Color: Black
Int. Color: Black
Mileage: 40k motor, 197k chassis
Engine: 2.2L DOHC VTEC (H22a)
Transmission: 5 Speed Manual
Modifications:
Exterior:
JDM Amber Turn Signals
5% Tint
Interior:
JDM Gauge Cluster
Skunk 2 Shifter ****
In-Car Electronics:
Greddy 52mm White Face Boost Gauge
Apexi AVC-R Boost Controller
Pioneer Head Unit
Greddy Black Turbo Timer
Chipped P28 W/ Datalogging
AEM Wideband A/F Gauge
Wheels/Tires:
Stock SI Blades
Suspension:
Skunk 2 Springs (2.5" Drop)
Aluminum Strut Bar
Lower Rear Tie Bar
Rear Strut Bar
Brakes:
Stock
Engine: (Here's the fun part!)
Skunk2 Racing Intake Manifold
South Beach Racing Replica Turbo Manifold
DSM 450CC Injectors
ST1 Stage IV .84 A/R .68T Turbo
Greddy Front Mount Intercooler
TiAl 40mm Wastegate
TiAl 50mm Blow Off Valve
Walbro 255LPH Fuel Pump
AEM Fuel Pressure Regulator
AEM Fuel Rail
Custom Intercooler Pipe
Transmission:
ACT StreetLite Flywheel
ACT F1 Racing 6 Puck Clutch
Forebidden Short Shifter
Now, with that setup, and an actual Dyno tune by a professional, that PSI should I shoot for to almost guarontee not blowing up after a month? Im thinking 3-4 psi. Correct?
Modified by whophlungpoo at 3:28 AM 9/3/2006
Old Sep 3, 2006 | 06:26 AM
hamadiscool's Avatar
Default Re: Best psi to run to guarontee longivity h22a (whophlungpoo)
i dont know much about turbos, but i know that stock h22s are good for 6-7 psi with a good tune. You can probably set a higher psi if you have a really great tune. Good luck man
Old Sep 3, 2006 | 06:36 AM
roller3804's Avatar
I would get a plx wideband instead. You can swap it out for the stock sensor wire it to directly integrate with hondata. So you only have one 02 sensor. You can run 8psi and possibly 10psi depending on who tunes the car. I would go with hondata s300 or Neptune.
Old Sep 3, 2006 | 08:19 AM
PrecisionH23a's Avatar
Default Re: Best psi to run to guarontee longivity h22a (roller3804)
You can integrate the AEM wideband into hondata as well. I prefer the PLX though over the AEM UEGO.
As far as psi, it is irrelevant to logetivity. It's all in the tune and the current health of your engine today. You can boost 7-8psi all day long properly tuned...
I'm guessing you are either running chrome or uberdata?
TylerC161
Mar 12, 2007 05:15 PM
TylerC161
Nov 19, 2006 07:01 PM
TylerC161
Sep 8, 2006 06:49 PM
oxhernandez
Aug 26, 2006 01:47 AM
AcuraFreak
Texas -OK -LA (Sales)
Aug 24, 2006 08:32 PM
