LCA'S
I was wondering if the 1992 civic LCA will fit on my 1991 Civic HB? Becouse they dont make any good ones for the EF... I was wondering cuz i see the ITR LCA will fit 90-95 civic sooo i was not sure..
the 90-93 integra rear lower control arms will fit with no problems for allignment. http://www.meganracing.com i emailed megan racing about that, and this is what i recived in reply.
i plan on using all of megan racings suspension components except the coilovers, and the front upper strut bar. i will be going with onmipower coilovers (see https://honda-tech.com/zerothread/1740327 ) for my info about why i am going with omnipower (yes i know about the past height issue), and i am using password jdm 3 point front upper strut bar instead of the megan one. also, the megan rear LCA are only 150$
Sgt,
I personally have a 1990 CRX and I can tell you that the LCA's do fit the
1990 CRX. All the suspension parts will, except for the C-Pillar bar because
the seat belt bolts are door mounted and not on the chassis itself. The 88-
89 CRX's had it that way. To use the seats you will need to get the brackets
from a company called Wedge Engineering. You can contact them at
http://www.wedgeengineering.net and they can custom fabricate them for you
because they already have our bolt pattern for the seats.
-Steve Johnson
Research & Development - Megan Racing Inc.
"The One That Gets it Done."
Sgt,
-Steve Johnson
stock rear lca from a integra 90-93 are totally different than EF and EG and DC. the shock mounting is considerably more outward, for whatever reason.
the distance from inner bushing to outer bushing may be the same, may be off by 1/16". im not sure. itll fit because its all generally the same design, but the shock itself will be positioned in a different location.
now, the AFTERMARKET crap is going to fit all the same, because they dont bother to make specific arms for each chassis. thats why theyre all interchangeable.
mambajunkie
Feb 20, 2004 09:00 AM
red civic standard
Jan 19, 2004 06:08 PM
