throwout bearing
Old Sep 2, 2006 | 08:32 PM
DelSolMarine's Avatar
Default throwout bearing
ok so when i push in my clutch pedal i get a loud squeek which i have come to conclusion its the throwout bearing/ rod... i have a b18c complete swap in my del sol and the squeeking is really a problem but im trying to figure out if it is something that make my clutch not grab as well... my car doesnt really launch good and im trying to solve my launching issues... what else can i do other a clutch kit to improve my launch... im also doing ecu chipping so that will help some 2 hopefully... anything else?
Old Sep 2, 2006 | 09:03 PM
96-EJ6 B18C's Avatar
Default Re: throwout bearing (DelSolMarine)
Step 1 is to get the tranny off that thing and check out the clutch, flywheel and throwout bearing. Step 2 will most likely be a clutch, I reccommend the Exedy stage 1, it works very well for mild setups. I'd worry about chipping the ECU after everything mechanical is resolved.
Old Sep 2, 2006 | 11:16 PM
Syndacate's Avatar
Sounds like a lubrication problem if anything. From how you're describing it it really doesn't sound like the throwout bearing. Maybe you just suck at describing sounds.
illi Adik
Honda S2000
May 11, 2009 07:24 PM
petty$rep
Oct 31, 2006 08:45 PM
maxogsr
Jun 22, 2005 06:46 PM
Edmund4th
May 18, 2004 03:43 PM
doublejz
Mar 9, 2004 01:19 PM
