half shaft hassel help me pleezzz
Old Sep 2, 2006 | 05:58 PM
hellracer24's Avatar
Default half shaft hassel help me pleezzz
i jus pick up a 91 crx hf wit an 93 LS it has a busted axel. i got it home around 4 today and started workin on it once it hit the ground i took the axel out the half from the hub to the female half shaft but the cup of the male side is still stuck in the female side. one of the homies said to hammer it till it come out....2 hr. laters it hasn't moved wtf should i do now i wanna drive her.
Old Sep 2, 2006 | 10:16 PM
mahatma's Avatar
Default Re: half shaft hassel help me pleezzz (hellracer24)
....so you can't get the driver's side axle out of the intermediate shaft....??
i'll go with the standard answer - pry bar
good luck
Old Sep 2, 2006 | 10:58 PM
Default Re: half shaft hassel help me pleezzz (mahatma)
tried it i'm jus lookin at now goin to the junkyard in the morning thanx tho
Old Sep 3, 2006 | 05:36 AM
3s0n3's Avatar
heat the female side to expand it and the male should come out ..... junk yard jobs under a car suck too.....
Old Sep 3, 2006 | 06:00 AM
SiRay13's Avatar
Default Re: (3s0n3)
try using a pickle fork.
Old Sep 3, 2006 | 09:08 AM
Default Re: (SiRay13)
coo i'll try those i hope using the fork works didn't even think of that....thanx
Old Sep 3, 2006 | 09:14 AM
boston's_rex's Avatar
Default Re: (hellracer24)
HEAT it works wonders
Old Sep 3, 2006 | 09:24 AM
ef_88_hatch's Avatar
like they said heat is good but dont heat it too mutch. or tou can go to a mashine shop
Old Sep 3, 2006 | 09:28 AM
jackinthetrunk's Avatar
Default Re: half shaft hassel help me pleezzz (ef_88_hatch)
what I do in this occasion I just take out the half shaft out with the axle attached to it. When you have it out the car hammer the crap out the axle until it lets go.
Old Sep 3, 2006 | 09:29 AM
eye.ha8.u's Avatar
THe easiest way IMO, is to have two people, one on the bottom of the car and one on the top by the alternator and pry both the top and bottom at the same time. It will pop right out if it has equal push from both sides, that little ring inside makes it a bitch with only one person.
Old Sep 3, 2006 | 10:48 AM
Default Re: half shaft hassel help me pleezzz (JayDeeEmm)
i don't have anything to heat it up with unless i set it out on the sidewalk....and i've been hammering for hours....and i can't find my fork....but i did jus come back form the junkyard and found a 93 teggy with what i need so if all else fails thats what i'm doin
B_Swapped93
Oct 28, 2013 01:38 AM
DTS
Oct 6, 2006 08:11 AM
turboman
Feb 10, 2006 05:14 PM
Cheeech
20
Dec 22, 2005 05:55 PM
