Problem with my car starting... HELP!
My cars battery died but i replaced it and aswell as a new starter and alternator but i get no power at all even if i turn the key half way and nothing...all fuses are good....what could be my problem???
first thing i would do... is go back and recheck all the wires n connections... might be an easy fix as a wire wasn't hooked up, is loose, etc... if thats not it then we can go from there, but thats the first thing you should do g/l
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdmShwiggEG »</TD></TR><TR><TD CLASS="quote">were is the Main Relay located???</TD></TR></TABLE>
Its under the drivers dash piece. If i were you i would get a Helms manual. its $70 but $70 WELL spent. i think its the best $70 iv spent when i got mine. It might be cheaper for your year tho. It will show everything you need to know about your car.
ill forsure get a manual for my car...but not only can't i start my car....not my headlights, radio, gauges, dome light or any light in the car besides brake lights and hazards dont work at all.
He says he isnt getting any power at all so its not the main relay. I had a problem like this and it ended up being one of the under the hood fuses was loose. It was stupid but it was keeping my car from getting power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg »</TD></TR><TR><TD CLASS="quote">He says he isnt getting any power at all so its not the main relay. I had a problem like this and it ended up being one of the under the hood fuses was loose. It was stupid but it was keeping my car from getting power. </TD></TR></TABLE>
X2
or there's a loose something...recheck everything and make sure everything is good...maybe a wire is old isnt makin contact at all with the fuses under the dash...wait i mean under the hood since thats where the 90amp battery fuse is
X2
JoeyEsco
Dec 14, 2014 07:13 PM
lrcrx90
Dec 16, 2006 07:48 AM
hurraquio
Feb 4, 2006 07:34 PM
