Do my valves need to be adjusted?
Old Apr 28, 2002 | 10:41 AM
89 CRX SI's Avatar
Default Do my valves need to be adjusted?
Hey all. Well if I drive around in 1st gear at lets say 1/4 throttle the car ginda gerks a bit but id fine if you give it a little gas. I have not driven the car much cause i just got it and never had insurence on it. I'm still working on it before i insure it so i was wondering is this caused by:
a: car being to cold
b: valves need to be adjusted
c: i actually let off the gas in first and thought i had it on
It only does it in 1st when I quickly shift in to second it seems to be smooth. It only does it once in a while to.
Im thinking its cause my car isnt warmed up all the way when I take it for a test drive around the block.
THX again
Old Apr 28, 2002 | 11:28 AM
89 CRX SI's Avatar
Default Re: Do my valves need to be adjusted? (89 CRX SI)
well
Old Apr 28, 2002 | 12:56 PM
EP3_05's Avatar
Sounds like a fuel problem to me. Maybe the fuel filter, pump, or injectors. Valves that are out of adjustment make a clicking sound. You will know for sure when they need adjustment.
Old Apr 28, 2002 | 01:37 PM
rallycivic's Avatar
Default Re: Do my valves need to be adjusted? (91civic)
had the same problem, cleaned my K&N and replaced fuel filter and car runs perfect
~Steve
Old Apr 28, 2002 | 02:16 PM
89 CRX SI's Avatar
Default Re: Do my valves need to be adjusted? (rallycivic)
Yeah it wasnt my car it was me hahaha I was at 5k rpm and let off the gas in 1st. I didnt even know i did it.
THX for your help guiys.
You can delete this post tortex
GoLowDrew
10
Jul 14, 2005 10:36 AM
sloweh3
Sep 24, 2003 09:32 PM
KCLude01
Sep 19, 2003 07:00 AM
thehondaguru
Jun 28, 2003 12:33 AM
JDM_ITR
Jul 16, 2002 10:21 AM
