Autometer Water temp gauge help.
Old Sep 2, 2006 | 12:41 PM
Mr.Death's Avatar
Default Autometer Water temp gauge help.
I installed an Autometer mechanical water temp gauge today and it doesn't want to work. It lights up but the gauge itself does not measure temp. I used the clock wiring harness for the 12v ignition power source for the light on the gauge and the gauge sender 12v source. I used the ground from the clock harness to ground the light on the gauge and grounded the gauge itself on the thermostat ground as the instuctions say to use a ground close to the temp sender for whatever reason. It lights up BUT does not read temp. Any ideas???? Perhaps a better ground for the gauge. Please help!!!
THanks
Old Sep 2, 2006 | 01:32 PM
Mr.Death's Avatar
Default Re: Autometer Water temp gauge help. (Mr.Death)
Anyone???
Old Sep 2, 2006 | 08:10 PM
Super79Dave's Avatar
Did you put the probe in too a coolant source? You said mechanical so i assume you have a themocouple that needs to go into a coolant source.
aboos
Dec 30, 2008 06:19 PM
innes887
Jun 13, 2007 11:12 AM
Mr.Death
Sep 5, 2006 01:36 PM
