So when I changed my trans fluid in my 00 accord se...
Old Sep 2, 2006 | 11:18 AM
Cannon Man's Avatar
Default So when I changed my trans fluid in my 00 accord se...
I had my trans replaced under warranty at the dealer. I went to change my fluid myself for the first time on this car and snapped the ratchet because the plug was so tight. Im guessing it was well over 100lb/ft instead of the recommended 36. Do you think there could be any damage done by having on that tight?
Old Sep 2, 2006 | 11:23 AM
hondadude's Avatar
Default Re: So when I changed my trans fluid in my 00 accord se... (Cannon Man)
As long as it didn't crack the case along the threads, no harm done. Look at the threads on the plug to be sure they aren't 'pulled' in one direction and if it looks okay reuse it with a new crush washer.
Old Sep 2, 2006 | 02:51 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cannon Man &raquo;</TD></TR><TR><TD CLASS="quote">I had my trans replaced under warranty at the dealer. I went to change my fluid myself for the first time on this car and snapped the ratchet because the plug was so tight. Im guessing it was well over 100lb/ft instead of the recommended 36. Do you think there could be any damage done by having on that tight?</TD></TR></TABLE>
give it a quick jab instead of turing it slowly, metal to metal contact(gasket/mating surface) will more prone to stripping if you turning it slowly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude &raquo;</TD></TR><TR><TD CLASS="quote">As long as it didn't crack the case along the threads, no harm done. Look at the threads on the plug to be sure they aren't 'pulled' in one direction and if it looks okay reuse it with a new crush washer.</TD></TR></TABLE>
Old Sep 2, 2006 | 06:07 PM
Cannon Man's Avatar
It looks okay. I finally managed to get it off with a heavy duty ratchet. I tried a "quick jab" but Im telling you this thing was TIGHT. I can't even imagine why they would do that, even if it was with a impact gun
Old Sep 3, 2006 | 06:42 AM
hondapower80's Avatar
Default Re: (Cannon Man)
I changed the fluid last night(42k) on a 4 cylinder '02. Next time, go to your local auto parts store and buy a penetrating spray called PB Blaster. Spray it on there, let it penetrate for a minute or two, then loosen the bolt. Also, we used a breaker bar from Sears instead of a ratchet. It came off very easily. Hopefully, you changed the crush washer as well.
One question, when did they replace your tranny, and what were the symptoms?
Old Sep 3, 2006 | 01:20 PM
Ross 2.0's Avatar
In a Junkyard near you.
there is no need to use any kind of penetrating oil on the plug. next time give it a light hit on the plug wih a hammer and with your ratchet attached to it give it a sharp hit with your hand and it will come loose.
1yesfan
May 27, 2016 12:20 PM
blouthan
Transmission & Drivetrain
Mar 6, 2009 05:01 PM
garrybloom
Dec 12, 2005 04:16 PM
TommyV
Honda S2000
Apr 14, 2004 08:53 AM
Y2KGreenGSR
Sep 28, 2001 12:11 PM
