Fuel pump installation
Hey guys, im running very rich on my 92 SI. I'm getting only 17 mpg mixed highway and city.
im pulling a code 43, faulty or failing fuel pump. could that be the reason for my awful mileage? where is the fuel pump located on a 92 lude? how do i access it? is there anyway of taking it out and cleaning it, or should i just get a new one? If anyone has a step by step for me to remove the pump, i would be realy grateful.
Thanks as always,
Joey
im pulling a code 43, faulty or failing fuel pump. could that be the reason for my awful mileage? where is the fuel pump located on a 92 lude? how do i access it? is there anyway of taking it out and cleaning it, or should i just get a new one? If anyone has a step by step for me to remove the pump, i would be realy grateful.Thanks as always,
Joey
ok i see, im a beginner, is it a hard thing to change? can i clean the fuel pump and re-install it? or when i get a code 43 it needs to be changed?
p.s. anyone know where i can get one cheap-ish?
I'm not sure the 5th gen pump fits in a 4th gen. Looking at the part numbers, they are slightly different.
http://www.slhondaparts.com/, compare the PN on here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">4th gens are the same. Take the whole back seat out, seat cross member and floor board in the trunk.</TD></TR></TABLE>
what do you mean by the seat cross member? that huge thing that runs through the middle of the lude? is it a hassle to take off? how would i do it please?
I removed the back seats (lower part). Do i also have to remove the upper part of the rear seats?
Thanks a bunch
Thanks a bunch
Ok so i took out all the seats and the center console and stuff
only took me like 30 mins or so. Now how do i remove the pump and install another one in? is it fairly simple? is there anything i should be careful of or do?
Thanks!
only took me like 30 mins or so. Now how do i remove the pump and install another one in? is it fairly simple? is there anything i should be careful of or do? Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">Remove 10mm bolts and feed/return lines. Lift pump up. Install is pretty much just like the dissassembly.
p.s. Go buy a service manual.</TD></TR></TABLE>
ya im gonna pick myself up a helms manual
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 »</TD></TR><TR><TD CLASS="quote">Don't forget to unhook your battery before removing your fuel pump
Thanks for the tip
</TD></TR></TABLE>Thanks for the tip
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguiner »</TD></TR><TR><TD CLASS="quote">
Thanks for the tip
Could also be a clogged fuel filter or injectors.....
Thanks for the tip
</TD></TR></TABLE>Could also be a clogged fuel filter or injectors.....
I don't know if everyones was like this but for my fuel pump I had to twist it 180* and pull up while trying to get it around the feed line... seemed harder than it should've been. Not that it was HARD...
i guess i could change the fuel filter while im at it... but i changed it less than 50k (50,000KM's not Miles) Ago... at the same time i had my injectors cleaned... im getting a CEL code 43 so im pretty sure it's the pump. I also have a huge hesitation problem when i drive the car after it's been sitting for more than an hour... it'll lose power and then regain it. once i accelerate past 4,000 rpm and i kick it a little, the problem goes away!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguiner »</TD></TR><TR><TD CLASS="quote">i guess i could change the fuel filter while im at it... but i changed it less than 50k (50,000KM's not Miles) Ago... at the same time i had my injectors cleaned... im getting a CEL code 43 so im pretty sure it's the pump. I also have a huge hesitation problem when i drive the car after it's been sitting for more than an hour... it'll lose power and then regain it. once i accelerate past 4,000 rpm and i kick it a little, the problem goes away!</TD></TR></TABLE>
yeah I had close to the same problem minus the CEL. It's more than likely your pump
cool, i have all the info i need (i think) to perform this operation myself lol. Ill take some pics of the progress and post them for future people who want to remove their fuel pump
I just installed my walbro 255lph for my turbo setup and i just took out the spare tire cover in the trunk and changed it that way...I didnt have to remove anything else. There are 8 10mm nuts and a 17mm bolt that held the line on.... It would be nice to have a pair of pliers to remove the vent hose from up top... I also had to twist it 180 degrees to remove...I feel this was easier than taking out the back seat.
i replaced mine a few months back. i went ahead and removed all the back seat supports you see right there and made it alot easier. after i took all that out though, i didnt feel like putting it all back in lol. i think ill just carpet over the open space
good luck its pretty straight forward from here.
