bleeding the clutch!!!!
Old Sep 1, 2006 | 09:37 PM
draztk_tendncies's Avatar
Default bleeding the clutch!!!!
ok so me and my dad were bleeding the clutch today, and some **** happened and needless to say he forgot to keep checking the clutch m.c. for fluid and.....lol yea its got more air in the lines than WHAT WE STARTED WITH!!!!!! so i have no pressure and i mean absolutely no pressure when i push the pedal down i have to lift it back up with my hand b/c it wants to stay against the floorboard!!
anybody have any suggestions???
thanks in advance.
Old Sep 1, 2006 | 09:39 PM
axtran's Avatar
get a line bleeder and read the helms
Old Sep 1, 2006 | 09:44 PM
Default Re: (axtran)
dont have a helms. if thats your pointers go suck a dick. thats a lot of technical support you douche-bag.
when i say does anybody have any suggestions i dont mean to read a ******* manual. i mean does anyone have any other METHODS of doing this ****, except for the conventional pump, hold, and bleed method.
Old Sep 1, 2006 | 09:47 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (draztk_tendncies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by draztk_tendncies &raquo;</TD></TR><TR><TD CLASS="quote">dont have a helms. if thats your pointers go suck a dick. thats a lot of technical support you douche-bag. </TD></TR></TABLE>
I was going to help you but now I decided that you're a huge asshat. Good luck not being completely mentally retarded next time. Jesus Christ - it doesn't even take two people to bleed the clutch. You don't have to shut the valve between pumps and only a complete ******* moron runs it dry on fluid. Also, it shouldn't take more than 40 seconds of pumping and filling to get it completely full of fluid.
Old Sep 1, 2006 | 09:49 PM
axtran's Avatar
you asked for suggestions. if you wanted to know how to bleed a clutch, ask that. i am assuming you know, that's what i get, i've made an *** out of you and me. good game, plz leave HT. Thanks Archi! I'm not the only one who sees how ridiculously defensive you get.
Old Sep 1, 2006 | 09:50 PM
EGwhat!!!'s Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
I was going to help you but now I decided that you're a huge asshat. Good luck not being completely mentally retarded next time. Jesus Christ - it doesn't even take two people to bleed the clutch. You don't have to shut the valve between pumps and only a complete ******* moron runs it dry on fluid. Also, it shouldn't take more than 40 seconds of pumping and filling to get it completely full of fluid.</TD></TR></TABLE>
x2
Old Sep 2, 2006 | 12:20 AM
nomoreavril's Avatar
i laughed so hard at this thread.
Old Sep 2, 2006 | 02:12 AM
boosted96midorihatch's Avatar
Default Re: (nomoreavril)
dumb ***
Old Sep 2, 2006 | 02:20 AM
92ehatch's Avatar
Default Re: (boosted96midorihatch)
here is how you fix it.
keep bleeding and WATCH THE FLUID
once you get no bubbles stop bleeding it. but now unfortunately you have to push all the fluid out.
i did this myself when changing my old clutch MC. i was using a one man bleed kit and didnt check it in time.
it just takes about an extra 30 mins to bleed it all back out. so be patient and pay attention
Old Sep 2, 2006 | 03:20 AM
Frozen E's Avatar
H-T White Ops
To the assclown creator of this thread...
Go to Wal Mart, buy 6' of clear fishtank tubing.
Hook one side to the bleeder, and run the other side back up to your fluid resevoir.
Fill resevoir and crack the bleeder open. Pump away for a good 2 minutes.
Keep an eye on the fluid level for the first few pumps since you're getting rid of air.
This will fix your problem.
Now quit being a ******* douche bag to people and tell your dad to stay the hell away from your car.
Old Sep 2, 2006 | 06:03 AM
Heretic:Si's Avatar
Default Re: bleeding the clutch!!!! (draztk_tendncies)
i can't believe the nerve of some of you people. you ask for help, and when you get a response you bitch about it. go buy a manual for your car you piece of ****.
Old Sep 2, 2006 | 07:12 AM
Kobal's Avatar
I've found that the best way to do this is to use a hand-operated vacuum pump or vacuum tester with a resevoir. I believe you can find these at your local auto parts store. Attatch the suction end of the pump to the bleeder screw on the slave cylinder and pump away, while carefully monitoring the mc and adding fluid as needed. It'll suck it through pretty quickly so be ready. After you've got fluid flowing through it, disconnect the pump and bleed it like a brake line to get any excess air out. The whole process should take like 15 minutes and it's a hell of a lot more reliable than doing the whole goddamn thing by hand.
Good luck!
Old Sep 2, 2006 | 08:23 AM
Unceasing Measure
Default Re: bleeding the clutch!!!! (Kobal)
While all of these responses are correct - mostly - it's much easier to just crack the valve, fill the master cylinder with fluid and use your hand to pump the clutch pedal. Whoever said it takes 30 minutes to do is higher than a kite. I bleed all my clutches the way I just described, and I've never ever had a problem. Takes me less than one minute and I do it by myself.
89sparks
Honda Motorcycles
May 24, 2020 05:27 AM
diviznrider
Feb 4, 2011 11:01 AM
preludeh22a1
Oct 29, 2008 07:54 AM
honda_racing101
Aug 13, 2007 06:20 PM
