101 on syncro damage wear
Old Sep 1, 2006 | 08:10 PM
ALL IMPORT's Avatar
Default 101 on syncro wear & damage
i put this in a diff thread but i figured i would give it its own might help some people. this was started because people were having a hard time shifting.
got bored so here is a little knowledge.
well if u take your tranny apart the syncros are made out off brass.
the reason for this is your always going to have wear on them because thats the way the tranny was designed. brass is the softest of metals so it wont harm any other gears when it flakes apart & wears down.
now i will show u some pics of some parts showing u what your problems are most likley.
first i will show 2 pics of a syncro hub & sleeve. the sleeve is what the fork attaches to & slides up & down over the hub & syncros switching gears.
alot of the time these 2 parts are overlooked due to the fact that everyone thinks its the "syncros" that are causing the problem so they just change them out alone depending on what gear it is.
notice between the teeth on the hub where sleeve has worn a groove in the middle & even a little notch in the side of the teth. this has happend all the way around the hub causing the sleeve to bind while moving. making it very hard to shift.
look at the light gray areas.
now on the sleeve if u look at the top & bottom of every tooth u will see a burr witch is causing most of the damage. most of that is from jaming gears to hard.
( damn nos motor, oh sorry) also these 2 pics are of 3rd/4th gear hub sleeve
now lets move onto a syncro. a new syncro is pointed at the tips along with the rest of parts, hub, sleeve, syncro gear ect..
if u think about it if u hit something that is pointed odds are u will slide off 1 side or the other.making things smooth. when it starts to get rounded of flat your obviously going to hit it, bind up a little then go around it thus making it hard to shift. now for the pic
notice at the top the fourth one in from the left u see a little burr & thier all pretty much rounded of the synco would have a little life left exept fot the burrs makes this part trash, this is on my second gear syncros, damn nos.
hope this explains a little & u learnd something
Old Sep 2, 2006 | 05:44 AM
IN VTEC's Avatar
Default Re: 101 on syncro wear & damage (ALL IMPORT)
It's usually not the teeth on the outside of the synchro ring that get damaged or wear. It's the inside rufffles that wear fastest. Compare a well used one to a new one and you'll see.
Old Sep 2, 2006 | 11:27 AM
ALL IMPORT's Avatar
Default Re: 101 on syncro wear & damage (IN VTEC)
i havent seen that really hapen but if u say.
Transmission & Drivetrain
29
Oct 7, 2009 04:56 PM
civic_66
Mar 30, 2008 07:24 AM
wallawee
Jul 21, 2007 03:57 AM
damsalprince
Honda Civic (2001 - 2005)
Jun 28, 2007 05:59 PM
duyfash0
Apr 19, 2007 03:43 PM
