throttle body
Old Sep 1, 2006 | 07:45 PM
honda305's Avatar
Default throttle body
i got a 95 civic dx with the stock D15 motor non vtec and my throttle position sensor went bad, my friend is giving me his extra throttle body from a D16y8 with all the sensors, will that throttle body match up with my intake manifold or will the car act wierd with it?? thanks in advanced
Old Sep 1, 2006 | 07:59 PM
SVOboy's Avatar
Pretty sure it'll match up, but you can just swap the TPSs if you want. You need to notch them little flat topped screws and unscrew them.
Old Sep 1, 2006 | 08:02 PM
xNOBOOSTx's Avatar
The whole throttle body will interchange if you want . The only difference is where the sensors are mounted on the throttle body.
Old Sep 1, 2006 | 08:16 PM
honda305's Avatar
Default Re: throttle body (honda305)
iight i put it on but im missing the gasket...now the car is slower
Old Sep 2, 2006 | 02:29 PM
honda305's Avatar
bump
Old Sep 2, 2006 | 02:35 PM
STPREZ's Avatar
Default Re: (honda305)
ya order a gasket from honda (real chip like $5) everything lines right up perfect and DO NOT MESS WIT UR TPS IF U DONT KNOW WHAT UR DOIN- it shouldnt need to be adjusted anyway
i have a ls throttle body on my mini me and my friend has a z6 throttle body on his b7 no modes require just grabing the map wire off fire wall(if u drive eg or ef) an plugin it to the one on the top of the throttle body
very simple job
Old Sep 3, 2006 | 04:48 PM
honda305's Avatar
Default Re: (STPREZ)
hows ur car running wit the ls throttle body???better?or same?
JDp0wer
Dec 15, 2013 01:25 PM
