REVERSE LIGHTS have never turned on. HELP!!!
Old Sep 1, 2006 | 07:07 PM
CRXDaddy78155's Avatar
Default REVERSE LIGHTS have never turned on. HELP!!!
Ever since I got my second used DX motor I have never had Reverse lights....I already checked the bulbs and fuses and I even checked the ones under the hood. I checked for votalges at the bulb connectors with the car in reverse and ignition on the on position and still no voltage...this probably has something to do with my short somewhere in the wiring I have from my EACV to the fuse 14.
I guess I can't do too much about this but thanks for the help you guys...I hope I can find the open or short.
Modified by 88DXREX at 12:45 AM 9/4/2006
Modified by 88DXREX at 12:46 AM 9/4/2006
Old Sep 1, 2006 | 07:26 PM
Coricivic's Avatar
Default Re: REVERSE LIGHTS have never turned on. HELP!!! (daddy78155)
check and see if the 2 wires on the tranny are connected all the way
Old Sep 1, 2006 | 07:35 PM
Default Re: REVERSE LIGHTS have never turned on. HELP!!! (Coricivic)
I wouldn't know where to look on the Tranny are they in an obvious place?
Old Sep 1, 2006 | 08:10 PM
b16civster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddy78155 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't know where to look on the Tranny are they in an obvious place?</TD></TR></TABLE>
yup in the front most part of the pass side of the tranny look strait down on the tranny to look and you should see 2 wires those r them
Old Sep 2, 2006 | 12:07 AM
Bob_760's Avatar
Default Re: REVERSE LIGHTS have never turned on. HELP!!! (b16civster)
While on the topic... where are those 2 reverse light wires on the trans supposed to go? I got my car with a B16A swap and the wires are just cut off the Y1...
Old Sep 2, 2006 | 09:17 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: REVERSE LIGHTS have never turned on. HELP!!! (Bob_760)
Just popped the hood to check it out, there's two wires coming from the sensor (green & yellow) and they come out from the main harness with the temp. sending unit and radiator fans' wiring. Hope that helps a little.
Old Sep 2, 2006 | 01:13 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: REVERSE LIGHTS have never turned on. HELP!!! (wiZCo)
look for green and yellow wires in the pic..
They should plug in on the engine wiring harness..
Old Sep 2, 2006 | 04:26 PM
31flavorscivic's Avatar
Default Re: REVERSE LIGHTS have never turned on. HELP!!! (88DXCRX)
I sliced those wires on accident while swapping. A quick solder fixed the problem.
Old Sep 3, 2006 | 01:14 PM
Thanks to your guys' help I found the 2 wires you were talking about.....I also read that there needed to be continuity to test the switch properly when the car was in Reverse across the yellow and green wires and they do so the switch is ok but I am still not getting my lights to turn on when I reverse. Does anyone have any ideas about what else could be causing this? I have already checked my fuses and made sure that the switch was all the way in the tranny as well as check for continuity across the yellow and green wires when in reverse.
Old Sep 3, 2006 | 01:39 PM
wiZCo's Avatar
Stouts 'n' Scotch
You might try checking for power at the wiring harness at the lights and making sure the bulb sockets aren't corroded.
Old Sep 8, 2006 | 09:09 PM
Bob_760's Avatar
Does anyone know what fuses are related to the reverse lights? I rewired my cut reverse switch wires and still dont have any lights... I checked the switch for continuity and it checks out while in reverse. I don't know where to start from here...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">You might try checking for power at the wiring harness at the lights and making sure the bulb sockets aren't corroded.</TD></TR></TABLE>
Are you saying the reverse light sockets should have positive power and the reverse switch gives it ground? My bulbs are new and my sockets dont look corroded at all. Certainly much less corroded than my old tail lights that still worked fine (allthough they would've worked better as fish bowls and their leaks filled my trunk with water ). Anyway any thoughts from here?
Thanks,
-Kurt
Old Sep 14, 2006 | 07:50 PM
sounds like your having the same problem as I am...I think I have a short or an open somewhere else in my car. I still don't have any reverse lights and my Switch checks out while in reverse as well. I have already replaced my bulb sockets too. I am pretty much stuck. I even checked for voltage with the car in reverse and nothing.
Old Sep 14, 2006 | 10:44 PM
Bob_760's Avatar
Default Re: REVERSE LIGHTS have never turned on. HELP!!! (88DXREX)
Yup, it is an interesting situation... I do alot of wiring but too much distance of wire seperates the result from the cause.... If I get around to tracing the whole system out and get it fixed I'll let you know, but I don't imagine I'll be that motivated about it anytime soon .
Old Sep 15, 2006 | 08:03 AM
88DXCRX's Avatar
Looking at the schematic,
It gets power from fuse #14 and the yellow wire
should be positive 12VDC in..
Once the switch is engaged,the green/black wire is energized
all the way to one side of the socket..
The other side of the socket should be ground..
PS,If the car runs,no need to check fuse #14..
It powers the main relay and without it,It won't run..
Old Sep 16, 2006 | 09:15 AM
My car runs better than it ever has...I just get frustrated looking at that dang Check Engine light when I know it's something in the wiring. Tracing it out really overwhelms me and I can't find the energy to do it since I feel I lack the expertise to find something like that. I am afraid I may not find it and have my car in pieces by the time I am done.
folta2169
Sep 3, 2007 11:42 AM
folta2169
Aug 17, 2007 02:35 PM
Hutch22
Nov 6, 2004 12:54 PM
LQQKITZME
Nov 6, 2003 05:41 PM
gleinz
Jul 11, 2002 08:58 PM
