Need a Pin Out! JDM CTR Cluster into a DC4 (1994 Integra RS)
Old Sep 1, 2006 | 05:10 PM
SW! Justin's Avatar
Default Need a Pin Out! JDM CTR Cluster into a DC4 (1994 Integra RS)
I have just acquired a JDM CTR Cluster, and I would like to put it into my 1994 Integra RS. And I was curious if anyone had a pin out, or information on how to complete this.
I've searched and only Found Integra Clusters into Civics.
Thanks in advance,
Justin
Old Sep 1, 2006 | 05:41 PM
SW! Justin's Avatar
Default Re: Need a Pin Out! JDM CTR Cluster into a DC4 (JCloke)
Old Sep 2, 2006 | 09:19 AM
SW! Justin's Avatar
Old Sep 3, 2006 | 12:47 AM
SW! Justin's Avatar
Old Sep 3, 2006 | 08:37 AM
SW! Justin's Avatar
Old Sep 3, 2006 | 11:29 PM
SW! Justin's Avatar
Old Sep 4, 2006 | 10:50 PM
SW! Justin's Avatar
Old Sep 6, 2006 | 09:54 PM
SW! Justin's Avatar
Old Sep 6, 2006 | 11:22 PM
HamiltonRex's Avatar
follow the traces on the back to each bulb/sensor etc.. And just write it all down, then make up your own diagrams.
Thast what ive done and it worked perfect.. You will have a Ground and Positive on each plug.. along with a dimmer which will go to a dimmer box thing.. and the screw RIGHT behind the speedo/Fuel/Tach etc.. Will be for the corespoding things.
Its not too hard, just time consuming, Good luck!
Old Sep 7, 2006 | 07:51 AM
em Dot's Avatar
POOPCheeks
i'm not sure if this helps but this is what i used to wire a 2001 GSR cluster into a 97 EK. could you work backwards from the diagram? heres the link https://honda-tech.com/zerothread?id=1053318
n1_kT
Northern California (Sales)
May 16, 2008 10:43 AM
ek9vboi2
Sep 6, 2006 09:36 PM
ek9vboi2
Mid-Atlantic (Sales)
14
Sep 6, 2006 09:34 PM
ek9vboi2
Northeast (Sales)
15
Sep 6, 2006 09:31 PM
ek9vboi2
18
Sep 6, 2006 09:30 PM
