Searching for poper Cat - Japanese CTR header to GoZigen 304 exhaust (2.5inch to 2.25inch)
Old Sep 1, 2006 | 12:47 PM
ogawa_jiei's Avatar
Default Searching for poper Cat - Japanese CTR header to GoZigen 304 exhaust (2.5inch to 2.25inch)
Edited
Old Sep 1, 2006 | 02:00 PM
ogawa_jiei's Avatar
Default Re: Searching for poper Cat - Japanese CTR header to GoZigen 304 exhaust (ogawa_jiei)
Edited
Old Sep 1, 2006 | 03:05 PM
Dodger2940's Avatar
look up SMSP, he is a memeber here and he would help you out.
Old Sep 1, 2006 | 11:30 PM
ogawa_jiei's Avatar
Default Re: Searching for poper Cat - Japanese CTR header to GoZigen 304 exhaust (Dodger2940)
Edited
Old Sep 3, 2006 | 08:03 PM
SMSP's Avatar
If you are running a JDM header and a JDM length cat back then the cats needs to be a length of 12" overall. I would take a close look at the tubing right at the B pipe flange to see if there is a reduction in diameter and also measure the ID of the B pipe flange. The actual Honda JDM cat has an outlet of around 1.9"-2" ID. With the OEM JDM header I usually remove the anti reversion chamber in the collector and clean up the welds in the ports. If your cat back is a true 60mm system then your ID at the flange is 2-1/4".
Old Sep 4, 2006 | 04:00 PM
ogawa_jiei's Avatar
Default Re: Searching for poper Cat - Japanese CTR header to GoZigen 304 exhaust (SMSP)
Edited
jeremy_dane
Feb 20, 2009 09:07 AM
supra360
Dec 8, 2006 05:18 PM
98cwitr
Dec 15, 2002 11:34 PM
1.8 Hybrid
Apr 29, 2002 11:31 AM
NSX Bob
Sep 7, 2001 03:55 AM
