Need help removing stripped nut
Old Sep 1, 2006 | 11:59 AM
LaOstha's Avatar
Default Need help removing stripped nut
Well i was told the other day that i needed to loop my dump tube into my exhaust because its still considered an exhaust leak and they wont pass me for my state inspections. So i went home to try and take my downpipe off to bring it to the shop. removing most of the bolts fine i come this one which is actullay a stud with a nut and try to loosen it but its on so tight that i take off all the edges of the nut thinkin i loosend it. I tried to use the propane torch and heat it up and use vise grips but im just taking more metal off the nut. I just need suggestions on how to remove the nut. the turbo is a 14b
Old Sep 1, 2006 | 12:24 PM
InEK's Avatar
keep on torchin! there are certain sockets that they make for rounded edges on nuts/bolts, its some kind of gripper company,,,anyways i think it might be to late for that,,,you probably could have saved it with that. Your best bet is going to be just torching it until it finally breaks loose.
Old Sep 1, 2006 | 12:35 PM
LaOstha's Avatar
Default Re: (InEK)
o ya i put pb blaster on it still nothing...but like you said im keep torchin it. is there a certain way to torch and do you thibnk the propane torch will get it hot enough
mitsuman's Avatar
Default Re: Need help removing stripped nut (LaOstha)
go to sears
http://www.sears.com/sr/javasr...66000
Old Sep 1, 2006 | 12:43 PM
LaOstha's Avatar
Default Re: Need help removing stripped nut (mitsuman)
^^^^^thats great thanks might purchase it
Old Sep 1, 2006 | 02:10 PM
SicilianSpeed42's Avatar
that craftsman bolt out set is very useful, its pretty cheap too
Old Sep 1, 2006 | 02:32 PM
mitsuman's Avatar
De nada.
90civicbns
10
Jul 14, 2013 01:57 PM
Tensa_Zangetsu
Dec 20, 2007 07:29 PM
idriveadelsol7
Dec 19, 2005 01:52 AM
GSRerrr
Mar 4, 2005 08:50 PM
slowride2
Jan 30, 2004 07:13 PM
