Almost done.....Power Door Locks
Old Sep 1, 2006 | 10:22 AM
dfung's Avatar
Default Almost done.....Power Door Locks
The last component that needs to be installed on my alarm is the power door lock trigger. Do I need to send wires all the way to the door through the hinge or can i access the door locks before the hinge? Before I start dismantling everything, just wanted to see if anybody already knows.
Old Sep 1, 2006 | 11:28 AM
JSPECSIR's Avatar
Default Re: Almost done.....Power Door Locks (foofght)
year and trim level
Old Sep 1, 2006 | 01:08 PM
dfung's Avatar
Default Re: Almost done.....Power Door Locks (JSPECSIR)
That's a good point! =P
'95 Del Sol Si
Old Sep 1, 2006 | 02:30 PM
JSPECSIR's Avatar
DIRECTWIRE™ WIRING INFORMATION - HONDA / DEL SOL / 1995 / Remote Start
[PRINT THIS PAGE]
12volts white + ignition harness
Starter black/white + ignition harness
Second Starter
Ignition black/yellow + ignition harness
Second Ignition
Third Ignition
Accessory yellow + ignition harness
Second Accessory
Keysense
Power Lock green/white - drivers kick panel
Notes: Door lock module in door. Remove silver cruise module in drivers kick panel and pull door harness out to access 20 pin plug. Lock wires on door side of plug.
Power Unlock green/red - drivers kick panel
Lock Motor
Unlock Motor
Parking Lights+ red/black green connector at fusebox
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger green/red - low in drivers kick
Dome Supervision use door trigger
Trunk/Hatch Pin green/black - blue connector above fusebox
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue AC 2-pin plug near distributor
Notes: Also at round gray connector next to hood strut.
Wait to start
Brake Wire green/white + brake switch
Parking Brake
Horn Trigger
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this
Old Sep 4, 2006 | 01:27 PM
dfung's Avatar
Cool thanks. Can I just yank the wire right out of the harnass or does it need to be removed in any fashion? And for inserting, is it merely a matter of just pushing it back in? I've never dealt with electrical harnasses before... Thanks!
hondacoupe05
Dec 31, 2008 10:21 AM
projektCRX
Audio / Security / Video
Aug 1, 2007 07:58 PM
slikz714
Jul 21, 2007 03:27 PM
truckramrod
Mar 5, 2006 07:00 PM
soccerman236j
Jan 30, 2005 06:48 AM
