how far does the castle nut on your lower balljoint go?
i recently installed new bushings on my front lower control arms, along with poly upper control arm bushings and poly compliance bushings. afterwards, i noticed a strange sound comng from the front when i hit small bumps or low curbs, sounds like a "plok". i suspect it's the lower balljoint, i torqued it down to spec, but when i look at it, the top of the castle nut is just flush with the ball joint stud. should the castle nut go further up on the balljoint stud? i was thinking it might be the poly bushings, but i would expect it to squeak, rather than go "plok"
yeah i used cotter pins, and the upper arms are torqued to spec as well. i'm having second thoughts about going to autox tomorrow because of this sound
butter99
27
Nov 28, 2008 04:53 PM
