need HELPS with ECU
Old Sep 1, 2006 | 09:16 AM
Rahxephon's Avatar
Default need HELPS with ECU
my setup right now:
2001 GSR with jdm ITR B18C 98 Spec run on Sohc VTec automatic modified KenJi chip P28
here's my question: How can go back to use OBD2 again for diagnostic/emission test? i've a virgin 01 GSR ECU plug it in but won't start....any helps or guidance would be appreciates ..TIA..
Old Sep 1, 2006 | 02:38 PM
zCivic's Avatar
Default Re: need HELPS with ECU (Rahxephon)
Is it the same ECU from the car. It may be the immolizer if from a different car.
Old Sep 1, 2006 | 10:57 PM
Rahxephon's Avatar
Default Re: need HELPS with ECU (zCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">Is it the same ECU from the car. It may be the immolizer if from a different car. </TD></TR></TABLE>
no it's different ecu from another car...how can i get it to work..anyways to bypass this ecu or i've to do something like getting another ecu? thanks by the way..
Old Sep 2, 2006 | 05:32 AM
zCivic's Avatar
well these are a few options I could find bout the immobilizer
http://www.ecu.ff-squad.com/imm.removal.htm
http://www.drdetailshop.com/556H.htm
May want to check some other places also forum.pgmfi.org has some info about them.
aziantegger10
Jun 20, 2008 11:56 AM
-Championship-
Sep 6, 2006 05:54 PM
ken'd
Jul 8, 2006 05:01 PM
Boosthead
Oct 1, 2005 08:24 AM
