b16 swap leaning out!!! what can i do!
Old Sep 1, 2006 | 07:42 AM
si90rex's Avatar
Default b16 swap leaning out!!! what can i do!
ok i did my b16a (90 crx si) swap 3months ago and everythings great, but it leans out bad! its not spark! i have new wires, plugs and rotor and cap. i just pulled the plugs and change them a few weeks ago and they were all white.meaning it s running hot. i have put a new fuel filter, and injector cleaner in it, it helped but still bad. i'm getting a 2000 si fuel pump hoping that will fix it. i think the stock pump isn't strong enough to power the b16. its fine when i get on it but just driving a normal speed say 35 to 40 it just misses. just spudders push on the gas abite and its fine. mainly when i'm in the range of 25-50% throttle. i put a new tps on it cause the one was broken, maybe i did set it right.
please help!!!
other mods are Cold air, flywheel and clutch. i have never touched the timing and there are no codes besides the knock senor but vtec works and it doesn't spudder in vtec.
any help would be great.
thanks
Old Sep 1, 2006 | 08:13 AM
BlackLudeSi's Avatar
Default Re: b16 swap leaning out!!! what can i do! (si90rex)
If its a first gen b16a running off obd0 you need two 02 sensors and most people dont wire them both. That can cause the problem you are describeing, each 02 sensor controls two cylinders. I have a b16a in a crx dx with stock pump and have no problems.
Old Sep 1, 2006 | 08:15 AM
si90rex's Avatar
Default Re: b16 swap leaning out!!! what can i do! (BlackLudeSi)
i have both o2 senors there pined right too.
Old Sep 1, 2006 | 08:38 AM
si90rex's Avatar
bump!
Old Sep 1, 2006 | 11:04 AM
si90rex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex &raquo;</TD></TR><TR><TD CLASS="quote">bump! </TD></TR></TABLE>
Old Sep 1, 2006 | 11:20 AM
mar778c's Avatar
Community Builder
Community Influencer
Get the knock sensor code fixed first. With that code, the ecu will severly retard timing. Which can cause bad partial throttle response.
Old Sep 1, 2006 | 11:28 AM
si90rex's Avatar
Default Re: b16 swap leaning out!!! what can i do! (mar778c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mar778c &raquo;</TD></TR><TR><TD CLASS="quote">Get the knock sensor code fixed first. With that code, the ecu will severly retard timing. Which can cause bad partial throttle response.</TD></TR></TABLE>
throttle response is fine tho. the knock senor code is werid i have a knock senor and everythings hooked up but it still puts out the code and vtec work perfect too.
it acts like its not getting fuel.
Boosted Chemist's Avatar
stock fuel pump is find for a b16a swap... i mad e 275whp on a stock 88 fuel pump
Old Sep 1, 2006 | 11:31 AM
si90rex's Avatar
Default Re: b16 swap leaning out!!! what can i do! (Boosted Chemist)
really! maybe i need to adjust my tps
Old Sep 1, 2006 | 11:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex &raquo;</TD></TR><TR><TD CLASS="quote">really! maybe i need to adjust my tps</TD></TR></TABLE>
try that its pretty easy to do.
Old Sep 1, 2006 | 11:41 AM
si90rex's Avatar
the only reason i would think its the tps is if it does spudder and i push on the gas slowly it will spudder all the way to the floor, but would that cause it to run lean?
Old Sep 1, 2006 | 12:09 PM
salman's Avatar
remove your ecu codes,
Old Sep 1, 2006 | 07:08 PM
4gencivicef9's Avatar
I am having the same problem, I have a b16a obd0 in a hatch dx and I have a air fuel gauge hooked up and when I start my car its lean and then It warms up and goes to rich, but then when I start driving it bogs when I hit the gas, also if I am going down the street and floor it, it will do the same....it goes to lean on the gauge and then disappears...
I was going to change my fuel pump, but everyone says it should be fine.
I am also throwing code 23 knock !!!!
I was going to get a fuel psi regulator...and adjust it. I cleaned the injectors and checked everything and cannot figure this out... if you figure it out let me know
Old Sep 2, 2006 | 12:48 AM
crxnj's Avatar
1st of all fix your code.....
also you say you just installed a new tps? was is calibrated correct?
Old Sep 2, 2006 | 08:52 AM
Default Re: b16 swap leaning out!!! what can i do! (Mr.speaker)
how can you adjust tps?
Old Sep 2, 2006 | 08:54 AM
Default Re: b16 swap leaning out!!! what can i do! (4gencivicef9)
you loses the screws and measure the voltage off the two outer wires i believe. At closes its supose to be .5 and wot 4.5. Make sure to go through all the rages to make sure there isnt a "Dead spot"
Old Sep 4, 2006 | 05:02 PM
si90rex's Avatar
u can't fix the knock senor code i have put 2 of them in one of them was brand new from honda, vtec doesn't work intell the cel comes on. which is when the car is a normal temp. my guess is tps adjustment ill try it wed, cause i have to work tomorrow.
Old Sep 4, 2006 | 05:08 PM
hates hondatech's Avatar
* B A N N E D *
easy fix ROOKIES if it drives fine when you mash the pedal your primary and secondary O2 sensors are backwards *****HINT**** primary meaning it goes infront of secondary meaning that on the exhaust manifold the primiry has to be on cylinder #3 on the header and the secondary on cylinder #4 on the header runners (bung holes).
Old Sep 4, 2006 | 05:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si90rex &raquo;</TD></TR><TR><TD CLASS="quote">u can't fix the knock senor code i have put 2 of them in one of them was brand new from honda, vtec doesn't work intell the cel comes on. which is when the car is a normal temp. my guess is tps adjustment ill try it wed, cause i have to work tomorrow.</TD></TR></TABLE>
if u change the sensor and the code doesnt go away, its your wirirng bro
Old Sep 5, 2006 | 04:55 AM
si90rex's Avatar
if u change the sensor and the code doesnt go away, its your wirirng bro</TD></TR></TABLE>\
its not the wiring, every thing works great, vtec works, just boggs like its lean. but yestarday i was airing up my tire and i could sell fuel. real strong but i started driving and it bogged anyways.
anyways i'll try to adjust my tps today, and if that doesn't help ill move on to o2 senors. but everything is pinned in the right spot checked it 3 times befor i started it.
thanks guys
Fresh'86
Mar 30, 2010 09:38 PM
ef9rida
Mar 25, 2009 09:15 PM
k_spec
Jun 9, 2005 09:00 PM
craiger
May 22, 2005 09:28 AM
Kevedge
17
Aug 13, 2004 10:19 AM
