blue smoke....
Old Sep 1, 2006 | 07:26 AM
GsrTurboCRX88's Avatar
Default blue smoke....
means head gasket right?
Old Sep 1, 2006 | 07:29 AM
SinSeven's Avatar
Default Re: blue smoke.... (GsrTurboCRX88)
yeah you have a blown head gasket.
nomotor's Avatar
i got that, i just noticed it but only when im flooring it
Old Sep 1, 2006 | 07:31 AM
SinSeven's Avatar
Default Re: blue smoke.... (nomotor)
Its smoking when you hit the gas cause its building more pressure within the motor causing the gasket to leak a little more.
Old Sep 1, 2006 | 07:40 AM
civickiller's Avatar
Default Re: blue smoke.... (SinSeven)
blue smoke is burning oil, white smoke is buring coolant
Old Sep 1, 2006 | 07:46 AM
Default Re: blue smoke.... (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">blue smoke is burning oil, white smoke is buring coolant
I thought that burning oil is black
Old Sep 1, 2006 | 08:09 AM
si90rex's Avatar
black smoke= gas smell the smokes coming from the exhaust does it smell like oil,gas,or coolant. go by smell not by the color of the smoke.
Old Sep 1, 2006 | 08:11 AM
Default Re: blue smoke.... (si90rex)
it has a very strong smell of gas
Old Sep 1, 2006 | 08:14 AM
si90rex's Avatar
pull the spark plugs what do they look like. white, black, oily??????
EJ1 wilcox's Avatar
As a general rule:
- Black smoke = fuel (too rich etc)
- Blue smoke = oil (leaking rings, valve stem seals etc)
- White smoke = coolant (head gasket... also some times it smells "sweet")
Are you getting any CELs?
Old Sep 1, 2006 | 08:15 AM
Default Re: blue smoke.... (EJ1 wilcox)
only cel is temp sensor
Old Sep 1, 2006 | 08:20 AM
si90rex's Avatar
is the temp senor hooked up by chance? i'm not saying ur stupid just some thing u might have over looked. but pull the spark plugs.and pull off the exhaust manifold stick ur finger in the ports is there oil or just carbon in them.
Old Sep 1, 2006 | 09:12 AM
philkehn's Avatar
black = fuel
Blue = oil
white = coolent or moisture
Old Sep 17, 2006 | 07:20 PM
snzh22's Avatar
Default Re: (philkehn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">black = fuel
Blue = oil
white = coolent or moisture</TD></TR></TABLE>
quick question...when u guys say u have smoke when ur flooring it, is it just one puff, or continuous smoke?
Old Sep 17, 2006 | 07:23 PM
nappyroots827's Avatar
Default Re: (95hprelude)
cel for coolant temp sensor would cause u to run rich, if its not working right, when your engine warms up its going to continuously spray extra fuel to compensate for what it "thinks" is still cold air going in to the engine...
Old Sep 17, 2006 | 07:42 PM
Monster.'s Avatar
you're not running race gas are you?
2kdrift
15
Feb 26, 2017 05:58 AM
tollickj
Nov 15, 2011 07:19 AM
EEWagonBol
Mar 31, 2009 07:43 PM
-[uSa]-Defcon_07
Aug 5, 2007 10:28 AM
BigIslandBoi
Nov 3, 2003 10:08 PM
