Aiming headlights on a 91
My GF's 91 needs the headlights aimed properly. I found two adjusting screws on each healamp, and you would think one is for vertical, and one horizontal, but apparently, that's not the case.
Is there some trick I'm missing or what here? It seems that they only move in a diagonal axis.
Thanks!
P.S. - I tried searching, but it doesn't seem to be working.
- TJ
Thanks!
- TJ
on my 89 its only 1 screw...its a long *** screw you'll notice it right on top of the headlamp.....Just pull infront a building and aim it to your needs..
just take it to a shop that can do a headlight adjustment. i got mine adjusted for $20 bucks and it was done porperly with computers and ****. the only reason i did it though cuz i went to HIDs and i had to replace my headlight.
