Axles not seperating.
Old Sep 1, 2006 | 04:42 AM
RaCk's Avatar
Default Axles not seperating.
Hello all
got a Prelude 92mod wich im trying to change the axles on. I've managed to seperate the axles from the transmission. But on the other side of the axle, i cant seperate it from the wheel thingie. I've gotten off the center lug. So the axle should be "free" but still, its like its welded tight.
Any suggestions? Does the ABS axles hang onto anything else?
Old Sep 1, 2006 | 04:54 AM
Finest's Avatar
Default Re: Axles not seperating. (RaCk)
If it's the first time removing the axle, it just takes a little more elbow grease to get it out of the hub. Thread the axle nut back on and tap on it until it breaks free. Otherwise, if you can get a prybar between the hub and axle, you can try it from the inside. But no, there's nothing else to remove, even if it's ABS.
Old Sep 1, 2006 | 05:03 AM
RaCk's Avatar
Default Re: Axles not seperating. (Finest)
Thx.
Thats what i thought myself. But its sitting so damn tight.
VTECROAR96typeR
Suspension & Brakes
Feb 21, 2009 08:27 AM
keepitngga1
Dec 21, 2006 05:00 PM
CustomX113
Dec 20, 2006 10:21 AM
flatblack-h22
Mar 7, 2006 11:57 AM
Prelussion
Nov 15, 2001 12:51 PM
