Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
EP's running hpde's
Old Aug 31, 2006 | 09:39 PM
03ephatch's Avatar
Default EP's running hpde's
if you drive an ep3(02-05 si) & have done hpde's i'd like to get personal pointers from you any help is appreciated.
what tires are you running?
what suspension set-up? (specs pls.)
what alignment are you set at?
have you had custom services done? (ie. coner balancing, full rollcage)
this ep is driven 4 times a week at the most. i am planning to take it to the november event in norcal @ thunderhill.
TIA
-clyde
Old Sep 1, 2006 | 04:53 AM
B18CXr's Avatar
Default Re: EP's running hpde's (03ephatch)
<------------have had over 20+ events in my chitbox
Old Sep 1, 2006 | 05:02 AM
George Knighton's Avatar
H-T Order of Merit
https://honda-tech.com/zero...d=179 <--Contact this guy, Scott Lear, too. He drives the Grassroots Motorsports USDM EP3 Si in Honda Challenge H3 every once in a while.
Old Sep 1, 2006 | 07:32 AM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: EP's running hpde's (George Knighton)
Didn't Victor track his EP3 a few times?
Old Sep 1, 2006 | 07:59 AM
H-T Order of Merit
Default Re: EP's running hpde's (Stinkycheezmonky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stinkycheezmonky &raquo;</TD></TR><TR><TD CLASS="quote">Didn't Victor track his EP3 a few times?</TD></TR></TABLE>
Yes, but he didn't change anything to do with alignment. I think he might have had the Type R suspension and Brembo when he went out with it. Not sure.
Old Sep 1, 2006 | 08:40 AM
sdcivic549's Avatar
I've got an EM2 that has seen alot of track work. It's the same suspension as the EP3 and RSX, just a little longer wheelbase.
Piece of advice, keep an eye on the OE front LCA bushing. As it wears it causes all sorts of fun toe changes and wheel hop off the corners.
I've got Progress coilovers, with 500F/650R springs, tho I've had the rear springs as high as 800. Progress sway bars, mugen aluminum front LCAs. Neuspeed solid tower brace.
Inside it's got a custom removable roll hoop and harness bar, Cobra Suzuka seat(almost sitting on the floor), Schroth 5pt harness.
Alignment is: -2* front, -.5* rear camber, 0 toe front, 1/16" (a smidge) toe out rear.
Tires are 215/40R17 Kuhmo MX's
Brakes are off the JDM integra R
It's good fun on the track, the rear should be set up basically as solid as you can stomach, the front needs to carry alot of static camber because the strut suspension doesn't gain camber well. Mine happens to respond very well to trail braking. The only downside is that even with an LSD the K20 has traction issues due to the camber and having to run a good sized front swaybar.
Old Sep 1, 2006 | 08:03 PM
03ephatch's Avatar
Default Re: (sdcivic549)
thank you very much guys. i thought b18 drove an ep? didn't you have a P1 project ep? wow, it's good to be back on h-t, george you've always been the go to guy. thank you as well sdcivic & b18cxr.
with the LCA bushing problem will a roll center adjuster do well with better bushings from say, ES?
yeah, i have seen & read about the GRM ep3, although i haven't seen it's current state after i saw pics of the build-up.
Old Sep 4, 2006 | 08:11 AM
B18CXr's Avatar
Default Re: (03ephatch)
yep, was my own POS..
The K24 Frank has long since been removed, got other odds-N-ends now.
Old Sep 4, 2006 | 04:24 PM
97 TYPE-R 312's Avatar
Default Re: (B18CXr)
I was running the TYPE-S brake conversion with Cobalt GT pads on Mugen Sport Suspension. I do need to get it out there now with the BC N+.
-Victor
Old Sep 5, 2006 | 05:51 PM
03ephatch's Avatar
Default Re: (97 TYPE-R 312)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97 TYPE-R 312 &raquo;</TD></TR><TR><TD CLASS="quote">I was running the TYPE-S brake conversion with Cobalt GT pads on Mugen Sport Suspension. I do need to get it out there now with the BC N+.
-Victor</TD></TR></TABLE>
i was also thinking of switching to BC N+ or the GC/ koni conversion.
at this time my set-up is:
-DC5 tein type flex w/ camber plates and bolts
-SS brake lines w/ hawk HPS
- (will be getting) 205 or 215/ 55/ 15's on stockies
-progress rear sway bar & pillar bar / sticking to stock front sway bar
- (may be getting) mugen center bar & side intrusion
- (may be getting) better seats
BAR296
Jan 10, 2006 05:21 AM
KekeK-18
Sep 25, 2005 05:10 PM
topspeed86
Aug 20, 2005 02:08 PM
Brownjd
Oct 19, 2003 01:06 AM
capcon83
Sep 12, 2003 10:15 AM
