h22 swap almost done
Im almost done with my h22 swap but i hit a brick wall
im done with everything but the map. of course the f had the "internal" map. the only problem ive go is that there is a pink wire on the chassis and not on my lude map. my haynes says that it is to the egr, What do i wire it to?
thanks for any help this is my first h22 swap
Internal map? CB chassis Accords have the MAP sensor in the black box with vaccuum lines leading from it on the passenger side of the firewall. What OBD is your H motor?
its out of a usdm 95 lude. its stamped on the block that it is a 94 i dont know if honda started obd II in 95 on the ludes or 96 like most cars
Im not sure what your asking but OBD2 started in '96. You dont need to wire up any MAP as you will be using the one on your firewall NOT the one from the H22.
swrdply400mrelay
Jul 2, 2003 09:15 PM
