Intermittent Cold start problem
Old Aug 31, 2006 | 06:43 PM
blumpfish's Avatar
Default Intermittent Cold start problem
Sometimes when I go to start my car in the morning, it turns over 8-10 times before starting, about 30% of the time. 40$ of the time it starts normally and goes to idle normally. the rest of the time it starts right up and bogs for a few seconds under 500rpm then goes to idle. what could be causing this? Fuel filter?
throws a few codes but nothing relevant i don tthink, VSS and secondary o2 sensor.
Modified by blumpfish at 7:58 PM 8/31/2006
Old Aug 31, 2006 | 07:03 PM
Contender25
Guest
Posts: n/a
Eh just tryin changin your fuel filter out and throwin some fuel injector cleaner or alcohol in the gas tank incase you got moisture built up, it's a easy simple thing to do first.
Old Aug 31, 2006 | 07:04 PM
Contender25
Guest
Posts: n/a
O yeah clean your battery connections, check your grounds, and clean your battery too, might as well for that "extra" bump when you start it, thats what i do every so often.
empirejr
Honda Civic (2001 - 2005)
Apr 9, 2011 09:33 AM
wanderinglost
Nov 7, 2008 08:31 AM
DrazoYU
May 14, 2005 10:47 AM
chuck23957
Dec 3, 2004 11:26 AM
racingrex
Nov 6, 2003 04:46 PM
