help with my crx dx 16 swap
hey guys i was wonderin if anyone knew wat kind of header i could get for my b16a civic xsi motor.. it has 2 oxegen sensor holes rigth next to each other and i can not seem to find a header liek this would it be ok to get on with a hole in the collector a another in the first down tube? also if i did that wud it be ok to length an o2 wire?
ahh good idea i fell dumb for not think of this..alos a honda swap book i just read say somthing about my crx hubs brake rotrs and calipers would not handle the b16.. if i swapped to the larger stuff.. would the bolt patter be the same?
i just bought a B16a and i asked a friend the same question u had. he told me to connect one of o2 wires to the other one so like the computer is thinking it is getting input from 2 different o2 sensors but u only have one. U will still have to run another o2 sensor wire. Snip one wire and splice the wire comming from the harness stright to the other o2 senor. its kinda confusing.
From: I told you to wait in the truck in Texas, United States
DX hubs work fine..That is a myth...
The stock ECU looks for two O2 sensors..Having just
one or even two wired backwards will make it run like crap...
justin1785
Mar 14, 2011 09:03 AM
DA91TEGGY
Mar 30, 2005 03:08 PM
sikcrx80
Apr 10, 2003 01:52 PM
RCautoworks
Mar 9, 2003 05:36 PM
