Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
How do I remove the Driver's side Door panel in my 2002 Si?
Old Aug 31, 2006 | 01:19 PM
Mateo02Si's Avatar
Default How do I remove the Driver's side Door panel in my 2002 Si?
As of last week my driver's side power window stopped rolling down all the way. The window motor is still strong as it pulls down about 1/3 of the way and then abruptly stops. I'd like to get in there and take a looky lou at it but i can't find any screws to take out of the panel and the internet is awash with garbage. Thanks for helping, and thanks anyway if no one knows.. although this seems to be a pretty easy question.
Peace,
Mateo
2002 Honda Civic Si
Old Aug 31, 2006 | 01:24 PM
toyomatt84's Avatar
Sanji
Wrong forum, check the EP3 Civic/RSX forum. This is for Non-Si's.
Old Aug 31, 2006 | 01:34 PM
black02civic's Avatar
Default Re: How do I remove the Driver's side Door panel in my 2002 Si? (Mateo02Si)
if its the same as the 02 civic lx then there sould be a plate looking thing behind the inside door handle take a small fine flat head and remove the plate it just pops in and easly pops out with a flat head there should be 2 screws behind there also in the hand handle in the middle of the door panel (where u normally pull the door shut) there should be a lil round plate there also get the flat head and remove the plate there should be one screw under there after that pull out the plastic cover( where the window switch is located on ) and then unplug the switch and there should be 2 more screws and take em out and pop the panel off it sounds its breakn but should be ok because it snaps off
hope this helps you
MidShipCivic
May 9, 2007 12:54 PM
eddie1681
Feb 24, 2003 10:33 PM
DRAG1320ciVHBKsi
Nov 29, 2002 09:50 AM
*Boostwerks*
Sep 13, 2002 08:52 AM
