troubles with BC stage IV, dyno tested...help
Old Aug 31, 2006 | 01:19 PM
deadman-ITR's Avatar
Default troubles with BC stage IV, dyno tested...help
Hello guys, here is my story…
I put my race car on the dyno last week and came up with this:
My setups is:
B18c5 block, ported and polished B18c5 head and Buddy Club Stage IV cams, Skunk2 dual springs, titanium retainers, ITR valves, b16 typeR pistons rings and rods, ITR Spec 98 header, Tanabe Extreme II Exhaust 60mm, ITR receiver with the custom made cold air intake, 63mm TB, MSD Ignition 400cc injectors and Hondata S300 with the p30 JDM ECU. The CR is 11.6 and VTEC point was set on 6200. ITR gearbox with LSD and spoon 4.96. Toda flywheel. Total engine rebuild last summer.
Why does it drop off so quickly, is it problem with the header or intake manifold or what? I don’t have any idea…
About my cams:
Buddy Club Spec IV
Spec IV cams are the ideal street/track camshafts. Spec IV cams increases the maximum lift to 12.3mm to give it an extra edge in high-end power. Specifications: Intake 306 duration, 12.3mm lift, Exhaust 302 duration, 11.8mm lift.
Thank you for help ))
Modified by deadman-ITR at 2:41 PM 8/31/2006
Modified by deadman-ITR at 2:42 PM 8/31/2006
Old Sep 1, 2006 | 04:43 AM
BoBo Racing's Avatar
Default Re: troubles with BC stage IV, dyno tested...help (deadman-ITR)
i think its ur cams buddy clubs are known for making great mid range power, not for top end power. ive seen it happen plenty of times on the dyno with these cams.
Old Sep 1, 2006 | 05:56 AM
Default Re: troubles with BC stage IV, dyno tested...help (BoBo Racing)
Really, and how about this words: "Spec IV cams increases the maximum lift to 12.3mm <U>to give it an extra edge in high-end power</U>."
Old Sep 1, 2006 | 11:49 AM
DonF's Avatar
Depends on where you degreed them at.
Old Sep 10, 2006 | 01:08 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoBo Racing &raquo;</TD></TR><TR><TD CLASS="quote">i think its ur cams buddy clubs are known for making great mid range power, not for top end power. ive seen it happen plenty of times on the dyno with these cams.</TD></TR></TABLE>
Come on Dave...mine died out at 8k:
BTW, im runing a very similar setup as you...
Old Sep 10, 2006 | 07:30 PM
Default Re: troubles with BC stage IV, dyno tested...help (_eoN)
now neo u call reving out to 8000 top end look at ur dyno u have great midrange ur cam dies at 8000 stock cams rev up to 8400 haveing top end power to me is reving out to 9k or more and still making power come on neo i thought u knew that
Old Sep 11, 2006 | 02:01 AM
ur torque is shitty bro
Old Sep 11, 2006 | 03:52 PM
Garrett's Avatar
not enough Compression for your cams
Old Sep 12, 2006 | 07:36 AM
Default Re: troubles with BC stage IV, dyno tested...help (Garrett)
CR is 11.6, it's not enough?!
Buddy club recommended CR range is 10.1-12.6 for this cams
Old Sep 12, 2006 | 08:22 AM
Natural Aspirations's Avatar
You plot looks like what I would expect to see from a build like yours, ~200whp seems to be the common limit of the OEM ITR header. If the B16 Type R pistons you are talking about are the CTR PCT pistons, your compression is much higher than 11.6:1, If everything is kept stock the pct pistons alone will put you above 12.7:1
Alot of the guys you see running big numbers have custom built headers, and many are not running through an exhaust. You could try using a large rthrottle body and having your intake manifold ported
Who ported your head, some guys can hurt.
Pay attention to what Don F says in your posts, he is always hinting tward an answer. the tool you need can be found here
http://www.newenglandhondarebuilders.com/
There are AAAAAAA LOT of other things to consider such as tuning/fuel/condition of motor. 200whp is nothing shabby for a 1.8l 4cyl engine especially with your mods.
Old Sep 14, 2006 | 01:16 AM
Default Re: troubles with BC stage IV, dyno tested...help (CRiXZc)
My CR is 11.6 We finished cylinders, after installation of pistons for reduction CR. As could not will get rid of a detonation on a degree 12.6
Old Sep 14, 2006 | 06:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadman-ITR &raquo;</TD></TR><TR><TD CLASS="quote">My CR is 11.6 We finished cylinders, after installation of pistons for reduction CR. As could not will get rid of a detonation on a degree 12.6 </TD></TR></TABLE>
What did you do?
Old Sep 14, 2006 | 01:47 PM
sorry for my english i've reduced CR from 12.6 till 11.6 after install b16 pistons
Old Sep 14, 2006 | 03:36 PM
I understand you reduced the compresssion ratio but how did you do this? Thick headgasket? If so you will want to make up the added deck height with cam gear adjustment.
I would say you may need to look into your cam timing.
Old Sep 15, 2006 | 05:00 AM
Black R's Avatar
25 Year Member
Default Re: (CRiXZc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRiXZc &raquo;</TD></TR><TR><TD CLASS="quote">I understand you reduced the compresssion ratio but how did you do this? Thick headgasket? If so you will want to make up the added deck height with cam gear adjustment.
I would say you may need to look into your cam timing.</TD></TR></TABLE>
.....in the post above yours, it looks like he's saying he put b16 pistons in to lower the c/r.
ej1252
Dec 3, 2009 11:48 AM
9civichatch3
12
Sep 6, 2007 06:03 PM
TeamSTEALTH GSR
12
May 12, 2004 12:40 PM
mugenDAxsi
Mar 31, 2003 11:31 AM
Stunna BEN
Apr 6, 2002 09:31 AM
