1985 Nighthawk 650 - Clutch slipping @ high RPMs?
Old Aug 31, 2006 | 12:12 PM
iLude's Avatar
Default 1985 Nighthawk 650 - Clutch slipping @ high RPMs?
So I've been riding my bike for a few months now. I've been getting a little more confident the more time I get on my bike. I've been taking it up in the RPMs, but I notice around 6k it seems to run out of power but rev quicker than before. I'm assuming the clutch is slipping while in gear, but I'm not sure. It engages fine from a start, shifts firm, but once I'm up in the powerband it seems to just slip in-gear.
Anyone have an idea? Also, if it is my clutch, how difficult are they to replace?
Old Aug 31, 2006 | 12:13 PM
4-ageTOg63's Avatar
Default Re: 1985 Nighthawk 650 - Clutch slipping @ high RPMs? (iLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iLude &raquo;</TD></TR><TR><TD CLASS="quote"> I'm assuming the clutch is slipping while in gear,
You are correct.
Anyone have an idea? Also, if it is my clutch, how difficult are they to replace?</TD></TR></TABLE>
Not hard at all.
iLude's Avatar
Default Re: 1985 Nighthawk 650 - Clutch slipping @ high RPMs? (4-ageTOg63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-ageTOg63 &raquo;</TD></TR><TR><TD CLASS="quote">You are correct.
Not hard at all.</TD></TR></TABLE>
Thanks for the insanely fast reply
Old Aug 31, 2006 | 12:15 PM
ricepapertiger's Avatar
He's gonna be the Official H-T Motorcycle Section's streched/slammed/stunna translator, he's gotta be fast.
Old Aug 31, 2006 | 12:17 PM
MSchu's Avatar
My Name is Nobody
yeah... bike clutches are insanely easy to remove and install, unless you break a bolt or strip a thread ... Dont beleive me do a google search for Insane Brothers
Old Aug 31, 2006 | 12:24 PM
iLude's Avatar
Default Re: 1985 Nighthawk 650 - Clutch slipping @ high RPMs? (MSchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">yeah... bike clutches are insanely easy to remove and install, unless you break a bolt or strip a thread ... Dont beleive me do a google search for Insane Brothers </TD></TR></TABLE>
Any special tools needed? Torque wrench, I'm assuming. I have a service manual at home so I shouldn't have too much trouble. What's the time-frame on a clutch install?
Edit: I was just looking at a parts catalog online, and found this..
I'm I going to need all of that?
Old Aug 31, 2006 | 12:42 PM
MSchu's Avatar
My Name is Nobody
whats wrong... springs and plates. Come on man, get on with it. the basket is not needed.
Old Aug 31, 2006 | 12:52 PM
D Day's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">whats wrong... springs and plates. Come on man, get on with it. the basket is not needed.</TD></TR></TABLE>
yea dude this is real easy. just take it apart and set the pieces out the same way you took them off. then just replace the worn disks and springs. no big deal. then put it back together the way you took it apart.
Old Aug 31, 2006 | 12:53 PM
iLude's Avatar
I've never worked on bikes before, its a little confusing to me. So I need parts 4,5, 6, and 8? Not sure what "basket" means.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D Day &raquo;</TD></TR><TR><TD CLASS="quote">yea dude this is real easy. just take it apart and set the pieces out the same way you took them off. then just replace the worn disks and springs. no big deal. then put it back together the way you took it apart.</TD></TR></TABLE>
So do I need to wait to disassemble it so I know which parts I need?
Old Aug 31, 2006 | 01:02 PM
D Day's Avatar
well i would take it apart to see the wear on the items first. if you arent that experience then i would have someone with you to kinda oversee the operation. if you havent done this type of work before it might be advantageous to have the manual and a torque wrench so you can torque everything to spec.
the main parts i see you will need are, 4 5 14 8 16 and i think 13. those are pretty common wear items and it is an older bike i would replace the bearings. and i dont know if you can just get the springs for item 1. schu will know about this subject than i but those would be the parts i would start with and replace anything that looks worn after that.
91tegra07
Feb 25, 2008 03:00 PM
ic89
Oct 17, 2006 11:59 AM
Garage 808 Hatch
Honda Motorcycles
25
Jul 22, 2006 11:08 AM
GoodKnight
Honda Motorcycles
56
Jun 13, 2004 07:20 PM
mattL
Honda Motorcycles
20
Sep 2, 2003 11:05 AM
